Question about Lexmark X83 All-In-One InkJet Printer
My lexmark x83 all in one printer will not power up. It went off overnight and won't come back on. I've unplugged, re-plugged, etc. and have it plugged directly into the wall. What gives?
SOURCE: will not print
Go to print. Prinrt comand comes up just fine. Press ok and nothing. Document pending is all I get. Printer seems to be ready but goes into power save waiting for next comand,
Posted on Jan 25, 2008
Ajkill
  • 2035 Answers
SOURCE: printer troubleshooting
Use this link to troubleshoot:;
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS507&relevance=1
Posted on Apr 04, 2008
SOURCE: Lexmark X83 "Unlock Scanner" error
I had this problem and am still getting it regularly
Lexmark support say remove power and usb leads take off loose top and take out papers turn it on its side and shake vigorously!
It works for me.
Best of luck...
Posted on May 04, 2008
  • 300 Answers
SOURCE: Lexmark X83
You can download the software from the link below -
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=227:5:0:95:0:0&emeaframe=&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&&req=:::-1::
Posted on May 18, 2008
I had the same problem and the solution is this: There is a red lever switch by the power chord on the scanner/printer. Above this red lever switch is the drawing of a lock in the "locked" position and at the bottom this red lever switch is the drawing of a lock in the "opened (unlock)" position. The lever on the red switch should point to the "opened" lock symbol (unlock). It the switch lever is pointing to the "locked" position of the lock symbol, flip it to the "opened" position and recycle power on the scanner by removing the power chord for a 30 seconds. If the lever is pointing to the "unlock" lock symbol, flip it to the "locked" position and then back to the "unlocked" position and recycle power. Good luck!
Posted on Oct 23, 2008
X9575 won't power on
Check with Lexmark to see if there is a reset button for unit
Aug 22, 2017 | Lexmark X9575 InkJet Printer
Lexmark X83 has system error A04.
Try to do the following:
  1. Reseat both cartridges in the printer and unplug the power cable for 30 seconds.
  2. Plug the power cable back in.
If you still experience issues please let me know.
-Serge
Mar 30, 2009 | Lexmark X83 All-In-One InkJet Printer
Printer
i have a lexmark x83 that is kaput. power cord is still ok. contact me. ckemmet@yahoo.com
Jan 23, 2009 | Lexmark X83 All-In-One InkJet Printer
Printer not commicating with PC
I have the same problem. I know now that Lexmark X83 does not work if you have Windows Vista as your operating system (at least not yet...).
Aug 10, 2008 | Lexmark X83 All-In-One InkJet Printer
My windows vista Business cannot install my Lexmark X83 All-in-one printer!
Lexmark is not officially making any driver for the X83 that will work with Vista because its a 32 bit printer and Vista is 64 bit. Sounds like some BS to me. So, I have the same problem, a perfectly working printer and an incompatible OS. My Mom was using an old mac and had an X83 printer which she loves. She now has a new PC running Vista. Only now, I have the problem of how to get the X83 to work with Vista. Supposedly the lexmark 5200 drivers will work. My suggestion is to power off and unplug the USB cable to the X83, and manually remove any driver(s) related to it that may have been installed using the system control panel device manager. Then attempt to install the xp driver for X83 per the post below. I'm going to then plug in the USB cable and power up the printer and see if it works (it probably won't) but I'm hoping it'll then cue itself looking for the 5200 series drivers which supposedly do work according to one post on MS forum, I quote:
"After reading all these posts I was both discouraged, but more determined than ever to get my X83 to run on Vista. I have to say the determination payed off! That's right...I just both scanned and printed 7 pages on my X83 running on Vista!!!! Here's what I did. I first installed the XP driver for X83 hoping I could dumb my laptop down to make it run on an XP version....no luck there, but when I did that, my laptop recognized the X83 as a Lexmark 5200 series which is also an all in one. I thought, well, if that's what it wants, that's what I will give it. If you go to the Lexmark website and look under downloads/drivers, there is a list that shows all compatible OS. The 5200 series is listed here with a Vista compatible driver. Once I downloaded it and went through the installation wizard....it worked LIKE A DREAM!!!! I hope this helps all of you as I also understood and felt your frustrations! Good luck!!!"
article source http://forums.microsoft.com/technet/showpost.aspx?postid=503767&siteid=17&sb=0&d=1&at=7&ft=11&tf=0&pageid=1
Lexmark 5200 series drivers http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1019285789_0_en,00.html
xp driver http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0 you'll have to type in a search for the driver enter X83 in the field, follow the steps...
Apr 21, 2008 | Lexmark X83 All-In-One InkJet Printer
Printer problem
Hi I went to lexmark.com and they told me to unplug usb and power cord. wait 30 seconds. replug, press menu button until manitenance shows up and select. go to self test, select. it should print something. if not take out cartridges and redo steps. it did work for me
Feb 18, 2008 | Lexmark X83 All-In-One InkJet Printer
Will not print
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83
Try unplugging the power cable from the back for a minute or two and plugging it back in.
Dec 31, 2007 | Lexmark X83 All-In-One InkJet Printer
Oct 13, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
