Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
When i plug in my external hard drive i get a clicking sound what does this mean?
  • 3,153 Answers
I termed the phrase "click of death" quite some years ago its nice to see others adopting it. Howver rather than giving you a YOU TUBE obscure reference I will give you useful information that might even get you your drive working.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 29, 2009
    Problem Solver:
  • 14 Answers
Hi, i had a simular problem it turrned out to be that my pasport WD (is this usb powerd?) you had to use the usb cord it came with because it couldent be powerd enough by a normal usb
  • 52 Answers
Its called the click of death, bad news I'm afraid. have a look on youtube about the "click of death"
3 Suggested Answers
SOURCE: Can no longer recognize my external hard drive
drive its ok, only electronic to the drive its death, you can buy cable and recovery your data
Posted on Dec 04, 2008
Endeir
  • 140 Answers
SOURCE: external hard drive wont connect
There may be a problem with the hard drive now. Please see a licensed computer technician from the company you have boughten the hard drive from.
Hope this helps ^^. Please dont forget to rate, Thanks
Posted on Mar 02, 2010
Dropped my external he'd
unfortunately clicking sounds on hard drives means that it is already damaged
Sep 04, 2012 | LaCie External USB 2.0 500GB 7200 RPM 500...
When i plugged my external hard drive, there's a
Hello there,
1. Is your Seagate portable external drive new? 2. Pug your external hard drive.
If it is follow instructions below. Guide is based on a Window7 operating system, you wont be having trouble if you're using Windows XP or Vista there will be a slight difference.
Note: you must be logged as an admin
a. Click start menu, right click-on Computer b. Left click on Manage. c. On Computer Management window. d. Left pane, Click Storage, Disk Management. you will see all available volume. e. If your Seagate is a new drive, it will appear as Un-allocated volume. f. Format the drive using NTFS file system before you can use it. you can also partition your new hard drive and assign a drive letter to the partition before you can use it.
Hopefully this guide helped. If you have questions feel free to ask me.
Thank you for using FixYa.
Aug 15, 2011 | Seagate 320GB Portable External Drive ...
My mac no longer recognized the drive. When it is attached it makes a clicking sound.
Clicking means a dead hard drive, usually the controller board is bad, but most shops won't repair this, hopefully it's under warranty.
Jun 10, 2011 | Hitachi Retail 0s02520 500 Gb External...
My external hard drive is making a sound like a loud clock. It would not allow itself to be read. What can be the problem?
Clicking sound means the platters inside of the hard drive are bad. They are touching each other which is bad. Only option is to replace the external hard drive.
May 26, 2011 | Computers & Internet
Hello I have a Toshiba canvio 3.0 external hard drive and up until today it was working perfectly fine this morning I turned on my HP dv7 and the external hard drive can not be recognized on my...
Hi kwooz109,
To fix the External HDD.
Take these steps.
First, click to open the Computer, on your "Desktop Screen"
In the (right, shortcut menu), select to open the Computer, by {right} clicking on it.
paul7of9_114.jpg Check to see if there's a External Hard Drive 'letter ie; [F:] ?
  • If the area is (Blank)?
  • Go to, and select the Control Panel, by clicking on the Start Button. paul7of9_115.jpg
  • Scroll to find: the"Hardware and Sound category, and click on it to open.
  • Next, select the "Device Manager."
paul7of9_116.jpg In the [Device Manager]; check to see: if there is a [Disk Drive] Icon?
  • You need to "Update the Drivers."
  • Open the "Disk Drive" by {2x clicking} on it.
  • Select the {Driver Button}, click on it to 'start the update.'
  • Follow all the instructions!
  • Click on the Apply and OK buttons when finished!"
  • Restart the Computer, to finish!"
!Attention: If 'problem still exist?
  • "Perform a "System Restore!"
{Start Button -> All Programs -> Accessories -> System Tools -> System Restore}
  • "Choose; most [Recent Restore Point] ie: Ext. HDD not' recognized!"
"Please let me know if you 'need' further assistance; by posting a "Comment 'or' Rating the Solution." Thanks, your 'response' is important!"
paul7of9
Mar 06, 2011 | Toshiba Canvio 750 GB USB 20 Portable...
When i plug in my hard drive it starts to make a clicking sound as the motor begins. It is not connecting. What do i do?
This doesnt always means the drive is bad, it can just be the cable...
My girlfriend bought me a verbatim 250gig external drive, which accoring to her was new from the shop but my PC couldnt pick it up, when connected, blue light flashes with a clicking nose... tried all usb ports but nothing... (wanted to take it back but she lost the receipt!!!!) after that didnt really bother with it until one evening playing FIFA on my sisters playstation and realised that the usb cable is the same as my external drive, so tried the cable and VOILA!!!!!!! PC picks it up and works as suppose to, till this day... So guys and gals, before going out to replace your external drive, borrow a playstation usb cable from your neighbor and have a go...
hope this helps
cheers!
Mar 16, 2010 | Western Digital Passport WDXML800UE...
Dropped it from a few inches. Computer wont recognize it. Tried hooking to my laptop, it loaded the drivers but still wont show up in My Computer.
try taking it apart making sure that the connections are plugged in
good and tight , also reboot the computer while its plugged in , if
still nothing listen for a spin up and spin down sound or a clicking
sound , the spinning up and down sound means the motor is
malfunctioning , a clicking sound means the units heads are
malfunctioning , if any of these problems exist let me know
my name is David or user name terminalcon just add attention
to; and I will help you further .
Jan 28, 2010 | Western Digital Elements powered by WD 320...
Acomdata external HD not read. Clicking sound.
Try taking it out of the casing and putting it into another external hard drive case. That is if you can, if its making a clicking noise it probably means your hard drive went bad or it means its not getting enough power to run make sure all the cords are hooked up tight. I had that problem once the hard drive wasn't getting enough power and i had to mess with it on the inside to make it have enough power. I'm not saying take the hard drive apart im saying take the casing off it and check the inside cords to see if they are tight enough. If that doesn't work leave a message and ill try to help again.
Jan 04, 2010 | Acomdata HybridDrive E5 Hard Drive
Maxtor 750GB External Drive Blinking White Light
If you hear a click-click sound it means that your drive's mechanics ia failing. BAD NEWS !!
Jul 06, 2009 | Maxtor Shared Storage II N01R010 1 TB USB...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
212 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
