Panasonic PT47WX49E Got horizontal lines all over the screen. Got picture & sound. Replaced low ESR cap in horizontal drive & both STK ICs in convergence but no change.
    President:
  • 1,462 Answers
The most common reason for the problem you are describing are failed capacitors.
These sets are assembled using the wave soldering process they are known for having cold solder connections. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad.
This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced.
The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment.
Try checking the replaced parts once again and check for the worn capacitors in the power supply, This could also lead to damage to all other parts
Please leave comment,if you need further assistance
RNJ VINODKUMAR
Posted on Sep 29, 2009
I HAVE A PANASONIC 50" PLASMA TV IT HAS A HORIZONTAL 3 TO 4" WIDE LINE ACROSS THE SCREEN HOW DO I REPAIR IT MYSELF
sounds lie a couple bad drive Ics on the buffer boards. You can get replacement buffer boards and free technical assistance from www.tvrepairworld.com
Nov 28, 2012 | Panasonic TH-50PX50U 50 in. Plasma HDTV
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
I have a Panasonic pt-53x42 projection tv. I believe i have a convergence problem. I have double lines running along bottom of screen..Any help please...
Yes,this problems is 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My sony kp 53v75 projection tv has an issue right now. The screen has lines that run horizontally across the screen that slightly distort the image. They move up and down slowly on the screen, Is there any...
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK comvergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost like $300-350 for parts and labors.
Nov 22, 2010 | Sony KP-53V75 53" Rear Projection...
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Had convergence problem; replaced 2 stk392;
100% Ur 2 STK convergence ICS are still dead.Ur ICS soldering some how,u got the ICS shorted.Or ur ICS not right kind of STK ICS,u replacing in ur convergence board.
Apr 07, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Wavy horizontal lines running through the screen
Ur tv convergence is dead.U must know how to solders?The 2 STK convergence ICS.and some or all it resistors must change.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Mitsubishi WS-55613 55" Rear Projection...
I have a samsung 65" rear projection TV. Model# HCN653W. The sound is find but the picture is now concave from left to right. For lack of the proper terminoligy it looks like you are looking at a bowl with...
Replace Both of your STK ICs Big black ics will have part number on them example STK392-110 also there is 2 resistors 2.7 ohms near STK replace them Call Mats for Parts 1-800-628-1118
Dec 14, 2009 | Samsung HCN653W 65" Rear Projection...
Picture on TV ''squeezed'' to center of screen horizontally
Check the horizontal trafo output voltage,the capacitors and the power supply voltage (135-155V dif.the tube diameter).
Aug 14, 2009 | Panasonic Televison & Video
I have a panasonic pt-51hx42. I was just
your convergence power supply blew a fuse & probably one if not both of the STK ics. Normally when this happens the short takes out the low value resistors connected to the ics.
it is common practice in the shop to replace both STKs and resistors
Jun 09, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
