Question about HP OfficeJet V40 All-In-One InkJet Printer
Error message: Incorrect Printer cartridge, when
Error message: Incorrect Black cartridge, when its clearly not
  • 615 Answers
The printer scan whatever been placed for it, so if you place a color it will read color and so on…now the printer read that the b lack cartridge is wrong according to your investigations, then the issue is between the ink cartridge and the printer scanner, so take out the black ink cartridge and do the followings, remove any type of materials that may cover the ink tank and make sure that he vent hole is clear, put the ink back after doing the same to the color and cleaning the inside housing, then use the software for self cleaning and alignment..
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Posted on Sep 29, 2009
How do I fix e07
I assume you have a Canon copier based on the E007 error code. The Fuser fixing film is torn and the Fixing film assembly or the entire fuser should be replaced. Very common issue.......You cannot reset that code without first replacing the part causing the code.
Dec 03, 2014 | Office Equipment & Supplies
My printer has decided that the black printer cartridge that has worked for months is the "incorrect cartridge". Figured it was a software problem, since my other printer now gives the same error...
I am having the same problem, I tried to replace the black cartridge and now it says it is the incorrect cartridge, so I put the old one back in and get the same error message.
Feb 09, 2011 | HP PSC 750 All-In-One InkJet Printer
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Incorrect right cartridge
Ive tried removing the right cartridge so I can print in black, but now , once I refilled the black one, it wont even let me print black!! this is desperate; can anyone help?
Aug 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Cartridge problem
removed both cartridges and reinstall again, pls make sure that the cartridges are seated correctly
Jul 15, 2008 | Dell 924 All-in-One InkJet Printer
Right cartridge incorrect
If it says to check the right cartridge (Black), replace it with a brand new one or one you know is good.
Walgreens will test and refill your cartridge for ~$10.00 (black).
I have heard of new OEM HP cartridges being bad.
The printer checks the cartridge level sensor and the electrical stuff.
Apr 21, 2008 | HP PSC 2110 Color Printer
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
HP OfficeJet V40 All-In-One InkJet Printer Logo
221 people viewed this question
Seeker5211
Seeker5211
