Question about Toshiba 53H71 53 in. Rear Projection Television
Blinking red light
Have no pic and no sound, just the flashing red light. There is a click when you connect the power cord and thats all. Can this be repaired by me?-
I am in the same boat as you are. My wife and I had watched the Steeler MNF game yesterday evening and today when I went to turn on the Pens game, all I got was a blinking red light and a "power on" sound...wtf...Can anyone help? I'm definitely not a techie nor have I ever soldered anything...
Posted on Nov 11, 2009
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
Red light flashes 7 times no pic or sound
This is a known issue on this television. The troubleshooting steps require that you have a DVM. If you dont have a DVM and just want to take a shot at fixing it, replace the MF power supply board. http://www.shopjimmy.com/catalogsearch/result/?q=37PF7320A+
Apr 07, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Power clicks on and red power light flashes but no picture
The problem might come from the fuse inside was blow out. if you have a multimeter then open the rear cover. The fuse lays near the power cord. Take it out and use Ohm meter to check it connectivity. If it is no connectivity meaning the fuse was blow out. Replace a new one with the same value (Ampere and Voltage). If it does have connectivity, the problem needs technician to find out as it relates to many parts on the circuit board.
Aug 11, 2009 | Sony KV-27S46 27" TV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
May 10, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Sony KDP-65S550 red light keeps blinking
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jun 28, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Turned off by itself, blinking red led at front
The clicking sound is the internal protection switch that kicked in because a fault had been detected.
First ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 28, 2008 | Toshiba 42HP95 Television
Sony kv32fs16 problem
Nov 02, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Toshiba 53H71 53 in. Rear Projection Television Logo
146 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
