Question about Sewing Machines
I have a Black & Decker Digital Advantage steam iron. The display window reads "error" and there is a beeping tone and of course no heat. How do I reset this or is it a sign of a bigger problem?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you are seeing the word Error on the digital display you will need to reset the digital display to clear this error. In order to reset that display, hold down the PROG/SYNC button and the CLR button on the display at the same time until the display beeps. This should reset the unit and clear the error code. If this doesn't resolves your issue then there is loose connector cable or the thermal fuse on the circuit board has blown and you'll need to change the fuse.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 29, 2009
I turned it on and the display reads 5P and just beeps when I try to do anything. My manual doesn't list this code.
Unable to assist without knowing the make & model of the machine. Error Code 5P varies depending on different make & model.
Nov 01, 2015 | Sewing Machines
How do I clean the top plate of press 4,please?
Wal Mart carry's a cleaner for steam irons that should work.
Sep 20, 2014 | Sewing Machines
STEAM PRESS NOT WORKING
Steam presses are fairly simple machines. You have a boiler and steam ports. First if you've been using tap water, you probably have a build up of minerals and eventually killed the heating element.
Get a new one.
Sep 09, 2012 | Sewing Machines
Auto Buttonhole Maker
pull down the buttonhole lever thats to the left of the needle & see
if that stops the beeping
Aug 25, 2012 | Singer Confidence 7469 Mechanical Sewing...
Cannot get the auto buttonhole to work..it beeps and I can't find the problem
there is a button hole lever to the left of the needle & you pull it
down gently against the button hole foot & the beeping should
go away
Singer advance 7422 beeps when i am trying to sew
are you getting a visual signal on your LED display ?
have you tried turning the machine off & waiting a few seconds & turning it back on again
have you tried cleaning the bobbin area for loose threads & lint?
how many beeps are there?
do you have a instruction manual for the machine? if not singer has one for free pdf download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 7422 ) & click search
Feb 01, 2012 | Singer 7422
Steam jets leave dirty marks on clothes
the tank has water left in it when put away,it will take some cleaning,it will not clear eaven after running water through it,sugest new iron req
Nov 17, 2009 | Sewing Machines
Machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Apr 08, 2009 | Singer CE-200 Quantum Futura Computerized...
Recieving a L6 code when trying to sew a button hole
You need to pull down the buttonhole guide which is the BLACK tab toward the back. I had this problem too, because I was pulling down the white tab in the front.
Jan 11, 2009 | Kenmore 19110 Computerized Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
