Question about Whirlpool TEDX640PQ Dryer
I have an Estate by Whirlpool driver model TEDX640PQ0. The dryer is not heating at all, and when on Auto Sense it runs all nite and only shuts off if you shut it off, but will shut off on timer setting, but still does not get hot. I don't feel the dryer is expensive enough to warrant paying service calls and parts for a repairman, so I was hoping it was something I could fix myself. Any ideas?
  • 496 Answers
My guess is, your heating element has gone out. Yes, you can fix it if you're so inclined to.
Here is a link to a set of manuals, including a parts list manual... this will help you in obtaining your part and illustrates how the unit is assembled.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=TEDX640PQ0&siteCd=WHRCOM
I hope this helps you... Good luck!
Posted on Sep 29, 2009
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
I have an estate TEDX640PQ0 Dryer that won't get hot. I Replaced the heating element but still nothing
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Whirlpool TEDX640PQ Dryer
No heat, timer not moving
Yes you need to replace the duct fuse and clear all air obstructions. I have repair photos HERE
Feb 17, 2010 | Kenmore 63942 Dryer
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
Dryer lost heat according to different cycles
the model number you have is for a gas dryer if this is an electric dryer then you can access the heating element by removing the back cover this has a small element you can remove it by taking the 1/4 inch screws from the sides of the element there could be two screws or just one remove the screws and pull the element out you con then visually inspect it but the best way is to ohm it out with a meter but your problem sounds more like a timer
Sep 18, 2009 | Estate TEDX640JQ Electric Dryer
Estate TEDX640PQ0 electric dryer makes grinding noise when running and seems harder to turn drum
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Apr 21, 2009 | Estate TEDX640JQ Electric Dryer
Whirlpool TEDX640PQ Dryer Logo
574 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
