I have a dvd player given to me with no cables. I have cables but when i hook it up i get no sound and then i hook another way and get no picture and no sound i have a plasma tv
  • 244 Answers
If connecting with scart leads make sure the lead is fully in both tv and dvd end,if this fails try a new lead
Posted on Sep 30, 2009
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Apr 13, 2013 | LG DVX583KH Player
How to hook up my dvd player to the t.v.
Hello
You haven't given any specifications about your tV here. Anyway, you can hook up the DVD player to TV using an AV cable. The AV cable will have three cables together with two RCA connections at each end of each cable. Look at the colour of them. Usually one Red, one White and an other will be yellow. Just connect them to the sockets of both DVD and TV accordingily, and switch ON both devices, select the tV input to AV1 or AV2. If all the connections are correct, you will see the logo of Mitsubishi on TV screen. This is the picture of AV cable. OK.
Nov 08, 2011 | Mitsubishi DD-8030 DVD Player
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I hooked up a new Telefunken 5.1CH DVD player HDMI/USB through CrCbCy video output jack but my picture has a blue-ish hue. I hooked the same cables up to my old DVD player and the picture looks fine so...
Set the FORMA, PAL, NTSC correctly, this is what it sounds like, that or somehow you got the Component video cables a bit mixed up, as thats what it goes like when that happens.
Mar 26, 2010 | Televison & Video
Just moved, hooked up DVD player to new TV. Sound
if you have a picture on the tv from normal channels and/or cable, then i would suspect the scart lead may have a bent pin at one end or both or is not inserted fully.
Feb 20, 2010 | GPX D1816 DVD Player
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Only getting sound but no picture!
Well, i had a look at the back of that Toshiba TV - make sure that the red, white, and yellow cables are hooked into the Video-1 slot of the Toshiba and that the Toshiba channel is changed to Video 1.
Then check your nameless DVD player and make sure the red, white, and yello cables are all hooked to OUTPUT slots that are in the same column or row - if I had you DVD manufacturer and model #, I could suggest some additional steps to check. Also, make sure your dvd player is in dvd playback mode.
-Tha Mp3 Doctor
Dec 31, 2008 | Toshiba 42HL167 42 in. LCD Television
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
