Question about GE GDS18LBR Bottom Freezer Refrigerator
Icemaker not making ice
Have as bottom freezer GE refrigerator that has a icemaker not making ice. Appears to have ice stuck inside of it.
  • John Tripp
    John Tripp May 11, 2010
    For some reason the model number above your post has no ice maker. Could you double check the model number located most times behind the fresh food section door or near floor just above the kick plate. Thanks, Sea Breeze
  • 193 Answers
Sounds like you need to replace the ice maker. The mold heater appears to be defective.The mold heats up prior to a ice dump. I donot believe it is worth repairing
Posted on Sep 30, 2009
GE FRENCH DOOR REFRIGERATOR DOES NOT MAKE ICE
First thing to check is if the freezer temperature is going down low enough for the ice maker to work - around 10 degrees. The icemaker thermostat will not activate the mechanism (cam motor) unless this requirement is met.
Nov 27, 2013 | GE Profile PFSF6PK Bottom Freezer French...
My ge refrigerator icemaker appears to be leaking there is about a 1/2" of ice in the bottom of my freezer
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Feb 15, 2011 | GE Refrigerators
GE PDS20MCP - the Ice maker is not making ice. Took out full tray of ice and has not made any since? Is there some reset button or something?
Before you the Water Valver - Shut your water off - disconnect the water line to the from the back of the refrigerator at the top where it goes into the icemaker. I used zip tie or something flexable to see if it would go all the way through to the
tube inside the refrig. If you have obstruction - use your hair dryer
to thaw the ice from inside the refrigerator tube. When the flexable item goes all the way through. Hook back the water line to the icemaker. You will have ice soon. If still not working, replace the inlet water valve at bottom back of refrig.
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/93259-ice-maker-repair.html#post227249#ixzz0pzmjhvPC
Jun 05, 2010 | GE Profile PDS20SFS Bottom Freezer...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Frig has water at door but no ice is made
Pour about 1/2 cup of water into the icemaker . If it dumps , replace the water valve . If not , replace the icemaker . Make sure the coils are clean of dust , etc... at bottom of fridge .
Aug 09, 2009 | GE CleanSteel GSL25JFTBS
Kenmore Elite Bottom Refer Internal leak
Hi, look and make sure the inlet tube to the icemaker is inside the fill cup. Make sure there is no ice build up in the fill tube also.
I hope this helps some, please let me know if I can help further.
Thanks Vic
May 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Monogram ZICP360SRSS - Ice cubes spill out of icemaker bucket
sorry, but not unless you want to get into spending some serious time.
Jul 29, 2008 | GE Refrigerators
Icemaker problem GE profile energy star 22.2 bottom freeser french door top
are you on a well system? it could possibly be a pressure issue with the water system not dilling all the way. stuck cubes will break icemakers.
Mar 30, 2008 | GE Energy Star PDS22SIS Stainless Steel...
GE GDS18LBR Bottom Freezer Refrigerator Logo
117 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
