I have an old Rel Q150e Subwoofer that has started to crackle even when nothing is plugged into it. Also the power light flickers when this happens. Messing with the controls at the back makes it stop and start intermitently. Do you know what the fault could be?
  • 537 Answers
SOURCE: Crackling Sound From Subwoofer
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Posted on Oct 29, 2007
  • 45 Answers
SOURCE: No power!
okay, this seems like either the fuse hase blown in the actual mains plug, or the mass fuse inside the device, it looks like this very small glass fuse, same size as an ordinary fuse, its just seethrough. see if you can get a replacement for it, you may need 2 open the unit to check if it has blown, it will be black or a "burnt" colour from inside! if you dont want to open it, take it to any electronics store, they are bound to check for you, but these fuses don't cost more that $1 or 50pence!
hope this helps
Posted on Dec 22, 2007
  • 238 Answers
SOURCE: No Output Subwoofer
hi, ya , some recievers have its setup where u have to enable the sub out,, check the menu carefully, also the player menu if the sub is on or off, let me know..
Posted on Jan 12, 2008
SOURCE: subwoofer makes loud popping crackle intermittently
im having the exact same problem thinking it was the amp i rigged up a different driver,the amp was fine.i knew the driver wasnt gone and after some looking and testing i got it down to wire mesh(i think a dust sheild,something)inside which was slightly rubbing on the coil,it worked fine loud when it was warm but cold there was bursts of bad feed back noises.
Posted on Mar 14, 2008
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
My Plaroid FLM-3201 LCD Television takes 4 hours to come on.
The power supply could be on the way to failing completely.
Aug 26, 2017 | Polaroid FLM-3201 Television
Tvee 20 subwoofer has distinct hum noise. Any advise?
1.Check the input cable or change it and see the result.
2.Test the subwoofer to a computer.
May 29, 2011 | Boston Acoustics TVee Model Two TV...
Speakers dead
check for individual speaker resistance. or in the dividing network for some burn fuse or coil.
Apr 05, 2010 | Logitech Z-2300 Computer Speakers
KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Dec 26, 2009 | KLH ASW10-120 Subwoofer
No sound from creative t3030 2.1 speakers
you checked adapter light the green light is show
Jul 23, 2009 | Creative Labs Inspire T3030 Computer...
Crackling and flickering of monitor continuosly
somehow i dont think theres anything you can do for it, judging by what you said, the overload was way too much for the screen
so, solution, get another screen, and get a decent surge protector, might not do much but it may prevent this from happeneing again
hope this helps
May 16, 2009 | E-Machines eMachines Monitor E15T4
My subwoofer started smoking-
a usual problem of a subwoofer just like my old sound system. Subwoofer generates a big heat on its device unlike ordinary speakers. better to send that to a technician to change a spare parts. it must be an ic problem got damage by over using.
thank you for using fixya
CHARCOIS
Nov 02, 2008 | Altec Lansing 641 Computer Speakers
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Toshiba a60???
if this happens even if your laptop is plugged in to a power source it could be that your battery is dead and you need to replace it
May 21, 2008 | Computers & Internet
SUBWOOFER
Sounds like the power supply in the subwoooooooofer box is dying.
Replace the whole thing . It's going to be the best way out.
Oct 25, 2007 | Sony STR-DE345 Receiver
338 people viewed this question
 Grubhead
Grubhead
