Question about Canon PowerShot A630 Digital Camera
Memory Card Error
Our camera is over 12 months old and has been working beautifully until recently. It now gives a memory card error when we turn it on. We've tried several new memory card (different brands) with no success. We've also tried reformatting the cards we've been using for months...again, no success. I've seen several comments on the internet about this problem, but haven't seen a solution posted yet. Thanks for any help you can offer...don't want to give up on it yet, it's been a great camera up until this point.
Two suggestions:
1. Try gently blowing clean air into the memory card slot. It's possible a bit of lint or dirt is on the contacts and needs to be removed. A can of compressed air will work for this.
2. (More advanced) If possible use a q-tip to gently rub the contacts for the memory card inside the camera. Again, you're trying to clean the contacts.
If neither works you'll have to consider bringing or sending your camera in for service. It's possible that it needs to be opened up for service and I don't recommend that you do that yourself.
Posted on Dec 19, 2007
Memory card is defective error message
Format the memory card on the same camera it is not a battery problem &also reset your camera
Sep 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Memory card error
Format the memory card in any other camera or pc.
Aug 27, 2009 | SanDisk 4GB Secure Digital High Capacity...
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
Memory card
Unfortunately, the A520 does not support SD memory cards with more than 2GB capacity, and doesn't support SDHC at all. (1GB max for MMC cards.) I know memory is much cheaper than when the camera first came out, but in 2005 2GB was about as large as you could get.
Jul 20, 2008 | Canon PowerShot A520 Digital Camera
SDHC Memory Card error
I had exactly the same problem with a 2 year old LX-1. The card worked fine on the computer, formated no problem but would not work in the camera.
I took a can of air and used maybe 3 one second bursts to blow out the card slot. Card immediately started working.
-prmolina
Feb 19, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
No Memory Card Error
May memory reader correpted or insert reversely memory card into reader.
Feb 18, 2008 | Canon PowerShot A560 Digital Camera
Memory Card Errors with Canon PowerShot S3
There most definitely is a solution to this problem. Follow this link for a step by step fix for the memory card error. It requires taking the camera apart but if the warranty is expired you have nothing to lose. Fix worked fine for me.
http://willj.net/2006/02/12/fixing-the-memory-card-error-on-the-canon-ixus-400s3/
Nov 22, 2007 | Canon PowerShot S3 IS Digital Camera
Have a Canon EOS SLR
Reformat the card in the camera then try Also use the menu system with help from the manual to establish the file size/ file type The higher the resolution the few the images able to be stored/ RAW and Tiff give but few SHQ give more HQ give even more but each with declining quality. Which is only 2 month old Card or Camera or Both? Either way having tried the alternatives if still in trouble return the 2 month old item for replacement.
Oct 06, 2007 | Canon PowerShot A550 Digital Camera
Memory card error
Try a smaller memory card size . I was trying to install a 4gb card and the guy at Kmart told me to try a 1gb card and that fixed the locked card error . No where in the instruction book did it address this problem.
Sep 24, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot A630 Digital Camera Logo
94 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
