Question about Maytag MDE9700AYM Electric Dryer
I have a MDE9700AYW. The unit powers on but when pushing start, it will not run (Drum is not turning)
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
fs234
Posted on Sep 30, 2010
Stopped working today. will not come back on at all. lights come on like it is working, but drum doesnt roll
Check the belt, Remove the bottom kick panel and clean out the lint. turn the drum and see if it is broken or loose.
Jul 07, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
Control Panel turns off
HI,
The PCB unit ie the control panel circuit board has gone bad. The probable cause of the same is moisture on the board.
Thanks
proton
Oct 21, 2008 | GE DCVH515EFWW Electric Dryer
MY MAYTAG MDE9700AYW WILL NOT TURN ON
Are you getting power at the console? Also, check to see if one of the breakers has not tripped. Dryer runs on 220v and you may have tripped one breaker that will show power to the unit but won't let it start.
Dec 24, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Turn power on dryer maytag neptune mde9700ayw push start and wont start and shows e5 code.tech sheet is missing from dryer
heatman101
May 04, 2011 | Dryers
Model MDE9700AYW: I set the timer for a certain amount of time (say 30 minutes). I come back 45 minutes later and the dryer is still running. There is also a "racetrack" in the display. No error...
Instructions
1. Break your load down into smaller groups. Large, saturated blankets, duvets, blankets and other upholstery can be too heavy for the MDE9700AYW to safely dry. Dry large large items one at a time with some smaller items such socks and underwear to better balance the load. One washer load should equal one dryer load.
2. Confirm that the cycle selector has been pushed down and the dryer door is latched shut. When the dryer door is opened, the cycle is temporarily paused to protect you from injury. Press the cycle selector down to resume the drying cycle once the door has clicked closed.
3. Examine the circuit breakers or fuses in the dryer's electrical circuit. The Maytag MDE9700AYW needs two active fuses or breakers, depending on your home, to operate its electronics and spin the drum. The dryer may not spin if either one of the fuses or breakers is inactive.
Feb 24, 2011 | Maytag Dryers
Dryer thumps on every rotation of the drum
Inspect the weld seam in the drum. Mine split in the front leaving a small hole. The thumping is the drum wheels running over the broken seam.
Sep 13, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
Dryer won't start ( Neptune MDE9700AYW ) just here a small click when you push to start
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 07, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model mde9700ayw will not start
Dryer Repair - The
Dryer Repair - The
heatman101
Oct 29, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag MDE9700AYM Electric Dryer Logo
128 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
