Question about Intel Motherboard
Looking for a motherboard supports Celeron D, Supports 4 or more gigs of ram. fits an atx case under 50$ refurbished is fine. I like this one cause it has everything i want including the 2 pci express slots but it goes into a btx case.... http://reviews.pricegrabber.com/motherboards/m/11841391/st=product_tab/
  • 68 Answers
These fit your needs but are a lil over 50$ but less than 60$
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138079&nm_mc=OTC-C173T&cm_mmc=OTC-C173T-_-Motherboards+-+Intel-_-Biostar-_-13138079
and
http://www.amazon.com/gp/offer-listing/B000O3QA9I/ref=asc_df_B000O3QA9I923000?ie=UTF8&condition=new&creative=380345&creativeASIN=B000O3QA9I&linkCode=asm&tag=cnet_mp-3411-20
Posted on Sep 29, 2009
Bought 2 gigs of RAM but Pavillion NY801AV-ABA p6100z doesn't recogize it.
I hope I can help!
Now, without knowing exactly what kind of ram you purchased, I cannot tell you for sure what the problem is, but this is the most likely, and most common problem. That is to say, your computer probably does not support whatever kind of RAM you purchased for it.
There are Multiple kinds of RAM (DDR, DDR2, DDR3 - not including older variations), and many different speeds. Each motherboard in every computer can run only certain kinds of RAM, and supports certain speeds. Sometimes a motherboard will support multiple speeds, but some are more limited.As far as the type, most motherboards will only physically support one type, so that should not be a problem as any other kind simply should not fit. Looking at the specs of your computer, it is also possible that your computer limits the size of a stick of RAM that must be placed in each spot (It looks like you cannot have a stick of less than 2 gigs in any spot). That is probably not the problem as you purchased 2 gigs of RAM. It should also be noted that your computer supports a maximum of 4 gigs of RAM.
All of that being said, the most likely problem is that you accidentally purchased the wrong speed of RAM. Looking at the specs of your computer, the only speed it supports is DDR 2 PC2 - 6400. It would probably be best to return the RAM your purchased and get some DDR2 PC2 - 6400 RAM. If this does not describe your problem, or if there is more to it, please ask!
I hope that helps!
Jun 15, 2011 | HP Pavilion p6100z PC Desktop
Need to increase ram but don't know how to find out how much board to support or what type.
Accessories included: i/o shield and cables only- no manuals or cdDFI CM33-TL/G Socket 370 Motherboard Intel Pentium III/ Celeron Onboard Video Audio IDE 3 PCI Micro ATX Motherboard Used Retail-MFG DFI Part:CM33-TL/G
2 DIMM sockets
Supports up to 1GB unbuffered DIMMs
Supports PC100 and PC133 SDRAMs BIOS
2 DIMM sockets
Supports PC100 and PC133 SDRAMs BIOS 2 DIMM sockets
Supports PC100 and PC133 SDRAMs BIOS 2 DIMM Sockets
Supports up to 1 GB of unbuffered dimms
supports Pc 100 and Pc 133 SDrams
Apr 04, 2011 | DFI CM33-TL mATX VIA 8601T/686B...
I have a acer aspire m1640, with the motherboard fails, if i can not fix it, what motherboard, acer apart, can i mount it? thank you
There are a few options you have on this, but if you want to maintain full compatibility with your current hardware, then you must purchase a motherboard that supports DDR2 533/667 MHz SDRAM since that is what comes standard in Acer Aspire M1640 Desktops.
A few options that would be similar to stock motherboard would be:
Foxconn G31MXP-K I7 or Biostar TForce TG31-A7
Those motherboards have similar specs to the stock motherboard and you can take a look at the specs of the Acer Aspire M1640 from this link below:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireM1640/AspireM1640sp2.shtml
Both those motherboards I have linked you too are microATX boards, which should fit fine in your case which may be a standard ATX case.
If you are willing to upgrade your ram, then your options open up to any motherboard that supports the Intel Pentium Dual Core processor. Since the stock motherboard also provides onboard video, chances are you don't have a video card plugged into your motherboard (unless you've upgraded that yourself) which means you should also look for a motherboard that provides onboard video so you don't have to purchase a video card.
Feb 26, 2011 | Acer Aspire M1640 Refurbished Intel...
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
Can i use 2.8ghz cpu for my p4s533-e?
this is what asus says:
arrow-org.gif Latest P4 CPU Support
The latest P4S533-E motherboard supports Socket 478 Intel® P4 processors, which utilize the most advanced 0.13um process technology to provide frequencies up to 2.53GHz
Mar 23, 2010 | ASUS P4S533-E Motherboard
I need a motherboard that can use the same case and everything els as the p4vmm2 My case is the ATX with Intel celeron 2,4GHz
you can use any ATX mainboard into an ATX case, they are universal. Your cpu will only fit boards with the same cpu footprint so you need to know what socket your cpu is.. lga775 is most common now. I would advise a Gigabyte EP45-UD3LR board. Excellent board and well worth the outlay.. no issues with windows xp or vista and you can expand drives and ram as you wish..
Nov 02, 2009 | EliteGroup P4VMM2 Motherboard
I ahve a P5VD2 - VM (SE) Motherboard -- and i think it doesn't match the frequenzy of my RAM as it is Kingston 1 Gig PC 6400 (800 mhz) while my board only supports up to 667mhz
Yepp, if you are lucky the mobo takes down the speed to the supported 667, if you are unlucky...it will cause you problems like blue screen suddenly shutdowns etc
Always use supported parts
Good luck to you
Dec 18, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Does msi motherboard P4M900M3 support this cpu Intel Celeron D CPU 3.20GHZ 512 Socket 775
MSI has two boards P4M900M3-F, P4M900M3-L.
Both of this will support your CPU
Nov 26, 2008 | MSI Computers & Internet
4 gigs of ram on xp 32 bit
Depends on how much memory your motherboard can accomodate. If *********** board can support 4 gig then just plug your ram and it should work.. xp supports up to 4 gig of ram so even if you connect an 8 gig,it will only recognize the 4gig. Hope this help,
May 11, 2008 | Microsoft Windows XP Professional
Not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Jan 17, 2008 | Compaq D310 (287944-CTO-4) PC Desktop
Intel Motherboard Logo
77 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
