Question about Insignia IS-LCDTV32 32 in. Television
Tv remote will not accept any codes for Sony dvd--will not accept 991 either, which is the code the manual says to use if no other codes will work
  • Insignia Master
  • 3,866 Answers
If remote is not accepting any codes this would be due to fauly batteries or the remote sensor that trasmittes the I/R is bad. You can go to www.remotes.com purchase the exact same remote you got there to solve this issue.
Posted on Sep 29, 2009
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
NEED REMOTE CODES INSIGNIA TV "IS TV040918"
Try the suggested codes contained in your remote user manual for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. If you still need help or want to share a remote code that works, participate in our online community: Community@Insignia.
May 26, 2010 | Insignia IS 20" TV040919 TV
Cannot program Insignia IS-TV040919 20" TV on a comcast 3 device remote (red OK button) None of the codes work.(10171,11204,11963,12002)
No problem, This issued will be only resolve with regular TV's, not LCD or PLASMA Tv's. Just press TV botton locate on the top leftside of the remote, right after hold the SETUP button for 3 seconds once the TV botton blink twice go and press 991 then 1 again, right after you have pressed 991 the TV botton will blink twice and when you press 1 will blink twice as well, after those steps keep pressing the channel up botton until your Tv shut off. That will work. Good luck
Jan 07, 2010 | Insignia Televison & Video
I have an Insignia TV and need the Sony remote code
According to InsigniaProducts.com, code 8043 may work for Sony remotes for your model of TV.
Aug 02, 2009 | Sony DVP-NS55P DVD Player
Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
Dec 29, 2008 | LG RC897T DVD Recorder/VCR Combo
Need code for Coby Dvd-254 Progressive Scan DVD/CD Player
i recommend getting a beafier remote some where in the 20 to 30 dollar range i owned one of these and they just sucked in codes and overall functionality i gave it to my dog went out next day bought a beafy remote
radio shack is not always up to speed on there equipment and sometimes outdated and a 7.99 uni. remote doesnt do it for me i think you can tell that by just being here on site asking for help
the remote bites
May 10, 2008 | Radio Shack (15-2147) Remote Control
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
Insignia IS-LCDTV32 32 in. Television Logo
50 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
