Question about Motorola Mobility i880 Cellular Phone
Turn on the transmission switch - Motorola Mobility i880 Cellular Phone
  • 111 Answers
Http://forum.gsmhosting.com/vbb/showthread.php?t=768471 this link should help you to solve your problem
Posted on Oct 03, 2009
My ignition switch won't turn on my 2007 Saab 9-3 . Steering wheel turns .key fob won't turn ignition switch.
Is it a manual transmission? I know some of the older
Saabs need the transmission in reverse to get the key out. Try wiggling the shifter and see if it helps with turning the key.
Feb 15, 2017 | Saab 9 3 Cars & Trucks
My 2003 GMC ENVOY won't shift out of park
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The automatic transmission shift lock control solenoid
The automatic transmission shift lock control switch
With the ignition in the ON position, voltage is supplied to automatic transmission shift lock control switch. Voltage flows through the normally closed contacts of the automatic transmission shift lock control switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid causing the transmission shift lever to be physically locked in the PARK position. When the brake pedal is pressed the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to be move out of the PARK position.
Shift Lever Does Not Move with Brake Pedal Depressed ?
  1. Turn ON the ignition.
  2. Press and hold the brake pedal.
  3. Attempt to move the shift lever out of the PARK position.
Does the shift lever move out of the PARK position?
Go to Testing for Intermittent Conditions and Poor Connections
Go to Step 3
  1. Turn OFF the ignition.
  2. Disconnect the automatic transmission shift lock control switch.
  3. Turn ON the ignition, with the engine OFF.
  4. Attempt to move the shift lever out of the PARK position.
Go to Step 7
Go to Step 4
  2. Leave the automatic transmission shift lock control switch disconnected.
  3. Connect a test lamp between the A/T shift lock control solenoid supply voltage circuit at the automatic transmission shift lock control solenoid and a good ground.
  4. Turn ON the ignition with the engine OFF.
Does the test lamp illuminate?
5
  2. Connect a test lamp between the ignition 1 voltage circuit of the park lock solenoid and a good ground.
  3. Turn ON the ignition with the engine OFF.
Go to Step 6
Go to Step 9
6
  2. Connect a test lamp between the ignition 1 voltage circuit of the park lock solenoid and the park lock solenoid ground circuit.
Go to Step 8
Go to Step 11
7
Inspect for poor connections at the harness connector of the automatic transmission shift lock control switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
Go to Step 13
8
Inspect for poor connections at the harness connector of the park lock/automatic transmission shift lock control solenoid assembly. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
Go to Step 12
9
Repair the open or high resistance in the park lock solenoid ignition 1 voltage circuit. Refer to Circuit Testing or Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 14
10
Repair short to battery positive voltage in the A/T shift lock control solenoid supply voltage circuit. Refer to Circuit Testing or Wiring Repairs in Wiring Systems.
Go to Step 14
11
Repair the open or high resistance in the park lock solenoid ground circuit. Refer to Circuit Testing or Wiring Repairs in Wiring Systems.
Go to Step 14
12
Important: Depress the button on the side of the shift lock actuator. With the button is depressed, cycle the plastic straw within the shift lever 3 to 5 times. The straw should move smoothly and freely except near the top of the travel where additional force will be required to mechanically actuate the park lock mechanism inside of the shift lock actuator. If there is stick/slip or abnormal friction while cycling the plastic straw or if the straw is altogether stuck in the lever, the entire control assembly (shifter and shift lock actuator) needs to be replaced. Refer to Transmission Control Replacement . If there is no abnormal friction, replace the shift lock actuator. Refer to Automatic Transmission Shift Lock Control Actuator Replacement .
Did you complete the replacement?
Go to Step 14
13
Replace the automatic transmission shift lock control switch. Refer to Stop Lamp Switch Replacement in Lighting Systems.
Go to Step 14
14
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Jul 09, 2016 | GMC Cars & Trucks
Stuck in park will not shift
The automatic transmission shift lock control is a safety device that prevents an inadvertent shift out of PARK when the ignition is ON. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The automatic transmission shift lock control solenoid.
The automatic transmission shift lock control switch.
The park/neutral position switch.
With the ignition in the ON position, battery positive voltage is supplied to the park/neutral position switch. When the transmission is in the PARK position the contacts in the park/neutral position switch are closed. This allows current to flow through the switch to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid, locking the shift linkage in the PARK position. When the driver presses the brake pedal the contacts in the automatic transmission shift lock control switch open, causing the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
Park Lock Solenoid
The park lock solenoid is a safety device that prevents an inadvertent shift out of PARK when the key is in the OFF position. The key must be in the RUN position to release the park lock solenoid. The system consists of the park lock solenoid. With the ignition in the ON position, voltage is supplied to the park lock solenoid. The park lock solenoid energizes through a permanent ground unlocking the shift lever. With the ignition in the OFF or ACCY position the park lock solenoid de-energizes and locks the shift lever in the park position.
DEFINITION: Transmission shift lever will not move out of the PARK position with the ignition ON and the brake pedal pressed.
Did you perform the Symptoms - Automatic Transmission Shift Lock Control tests and all the necessary inspection?
Go to Step 2
Go to Symptoms - Automatic Transmission Shift Lock Control
  1. Turn ON the ignition, with the engine OFF.
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO Go to Step 3
  4. Press and hold the brake pedal.
  5. Attempt to move the transmission shift lever out of the PARK position.
Does the transmission shift lever move out of the PARK position?
Go to Step 6
Go to Step 4
  2. Disconnect the automatic transmission shift lock control solenoid.
Go to Step 7
Go to Step 5
Inspect for poor connections at the harness connector of the automatic transmission shift lock control solenoid. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 10
Go to Step 9
6
Go to Step 10
Go to Step 8
7
Repair the short to battery positive voltage in the A/T shift lock control solenoid supply voltage circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 10
8
Oct 13, 2015 | 2006 Hummer H2
New rebuilt Transmission,now have starting problem?
was the neutral safety switch adjusted try moving the shifter slowly threw the gears while turning the key that wilol show you YOU MUST KEEP YOUR FOOT ON THE BRAKE THE TRANS MAY NOT BE IN NEUTRAL WHEN THE SWITCH IS
Aug 11, 2012 | 2002 Chrysler PT Cruiser
88 s10 2.8 5 speed have power to lights, blower, radio, but wont turn over when turning key no clicking nothing wont even start or turn over by crossing solenoid
Since you have power to your accessories, here are a few more things to consider:
1: Automatic transmission not in park or the neutral safety switch is faulty
2: On manual transmissions clutch pedal not depressed or or clutch start switch failure
3: Broken or loose wires in the starting circuit. Inspect all wires and connectors at the battery, starter solenoid, and ignition switch
4: Starter motor pinion jammed in flywheel ring gear. Manual transmission. place transmission in gear and rock the vehicle to manually turn the engine. Remove starter and inspect pinion and flywheel
Jul 29, 2011 | Chevrolet S 10 Cars & Trucks
Back up lights not working Where is switch to turn
Switch is on the transmission. Exact location depends on whether you have automatic or manual transmission. I have pasted pictures for each case below. Just look around the transmission for these parts. OK?
automatic trans:
manual trans:
Dec 06, 2010 | 1989 Nissan Pathfinder
How do you replace the neutral safety switch
Mode switch is on the LH side of the transmission.
Unclip the mode switch cover.
Disconnect the nut that holds the selector lever to the mode switch and pull the lever away.
Disconnect the harness from the mode switch connector then unbolt the connector and its bracket from the transmission and unbolt the mode switch itself from the transmission.
Replacement is the reverse of removal.
Do the following to align:
Loosen the switch hold down bolts. Turn the switch until the slot in the switch lines up with the bushing and insert a drill bit into the slot. Retorque the switch to transmission bolts.
Torque settings: Mode switch bolt 13 N.m., selector lever bolt 23 N.m.
Sep 11, 2010 | 1998 Isuzu Trooper
!998 jeep Cherokee-no reverse lights...left turn signal
Replace turn signal switch on colum probubly emergrncy and turn combo check your back up switch on man transmission. if auto transmission check selector switch on linkage.
Jul 30, 2009 | 1998 Jeep Cherokee
Thumb switch on automatic transmission won't go in so I can shift
YES IT DOES. CHECK AND MAKE SHURE YOUR BRAKE LIGHTS ARE WORKING. IF THEY ARE NOT WORKING , THE SWITCH IS BAD
Dec 16, 2008 | 2000 Jeep Wrangler
Motorola Mobility i880 Cellular Phone Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
