Question about Texas Instruments BA-II Plus Calculator
When I multiply decimal numbers together, it gives me a wrong answer. For example: 0.02 x 0.03 will show up as 0 instead of 0.06
  • Ronald Park
    Ronald Park May 11, 2010
    Is the decimal setting set at floating? If not that is the answer that will come up.
  • 53 Answers
Put the equation into parenthesis
Posted on Sep 29, 2009
7/3(x+9/8)=20
First convert your fractions into decimals. From there you want to multiply your decimals together, and then subtract that total from 20. That should give you X. So, 7/3 translates into 3 1/3, which becomes 3.33. 98 becomes 1 1/8 which translates to 1.25. Multiplying these gives you an answer of 3.74625, which can be rounded up to 3.75.now subtract 3.75 from 20 and you should get 16.25. This is X.
Nov 14, 2014 | Office Equipment & Supplies
Changing from x10^-3 to decimal
Two alternatives:
Press SHIFT MODE 6 then a digit greater than 2 to specify the desired number of digits to the right of the decimal point. For example, of you select 3 the number will be displayed rounded off to 0.004 .
Press SHIFT MODE 9 2 to select the NORM2 mode.
Be aware that in any mode if the magnitude of the number drops below 10^-9 then the calculator will automatically switch to scientific mode. The calculator can't display more than nine digits after the decimal point---the display just isn't big enough.
May 17, 2013 | Casio FX-115ES Scientific Calculator
Convert decimal fraction to binary
None of these solutions answer his question. When converting a fraction or any number with decimal places to Binary, the TI-89 gives "Error: Domain error." For example, entering .6875 [2ND][MATH][BASE][BIN] does not work. I haven't found a way to do it with built in functions. In order to do these types of conversions, I use the following method.
Convert: 0.6875 to Binary
- left of decimal is a 0, so write down a 0, then a decimal point: (0.)
- multiply .6875 x 2 = 1.375 left of decimal is 1, write a 1: (0.1)
- drop the 1 and multiply .375 x 2 = .75 left of decimal is 0. write a 0: (0.10)
- multiply .75 x 2 = 1.5 left of decimal is 1, write a 1: (0.101)
- drop the 1, multiple .5 x 2 = 1. left of decimal is 1, write a 1: (0.1011).
- since there is no more fraction, the final answer is (0.1011). Hope this helps.
Jan 27, 2012 | Texas Instruments TI-89 Calculator
I'm getting answers in fractions when multiplying decimal numbers like 5.5x3.5=77/4 instead of 19.25. Can someone help with this, I have a test tomorrow and I need to figure out what's wrong with the...
In the default MthIO mode the calculator will always try to show exact or symbolic results. You can convert a single result to decimal by pressing the S--D key. If you want all results to be in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Nov 11, 2010 | Casio FX-115ES Scientific Calculator
My Ti-84 plus gives me an answer of "4E-4" when I multiply .02 times itself. How can I get it to show me the decimal answer instead of the E
Unfortunately, you can't. From the manual:
If [...] the answer cannot display in 10 digits (or the absolute value is less than 0.001), the TI-84Plus expresses the answer in scientifc notation.
Oct 05, 2010 | Texas Instruments TI-84 Plus Calculator
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
Nov 12, 2009 | Texas Instruments TI-89 Calculator
Casio fx-300ES Default answer readout?
Generally, MathIO gives results in fractions or radicals. But sometimes it does not. I tried multiplying or dividing fractions or radicals by integer numbers, and once in while I got a decimal result and was unable to cast it into a fraction or a radical. I was not able to find the pattern.
In lineIO you only get decimal results.
What can one tell you that you cannot determine for yourself? If you appreciate the functionalities of the MathIO, it seems like an insignificant price to pay to press ONE button to switch between displays. It needs to be done ONLY once, for the last result one wants to record.
Your calculator, Your rules. But sometimes one cannot eat the cake and have it too.
Oct 20, 2009 | Casio fx-300ES Calculator
When I try to divide numbers that would leave a remainder like 1 divided by 6 which should give me an answer like 0.16666666666 instead all it says for an answer is 1/6. it does say in the manual to input...
To convert from fractions to decimals, and from decimals to fractions use the [S<-->D] key. If you want your decimal results to have a fixed number of decimal places press [SHIFT][SETUP][6:Fix]. Screen shows Fix 0~9. Enter the number of decimal places exemple 3.
Dans ce cas 1/6 is displayes ase 0.167.
Hope it helps.
Sep 23, 2009 | Casio FX-115ES Scientific Calculator
Convert 4 2/9 to a decimal
Step 1: Find a number you can multiply by the bottom of the fraction to make it 10, or 100, or 1000, or any 1 followed by 0s. Step 2: Multiply both top and bottom by that number. Step 3. Then write down just the top number, putting the decimal place in the correct spot (one space from the right for every zero in the bottom number) Example 1: Express 3/4 as a Decimal Step 1: We can mulitply 4 by 25 to become 100
Step 2: Multiply top and bottom by 25:
×25 left-up-over-arrow.gif 3 = 75
4 100 left-under-over-arrow.gif ×25 Step 3: Write down 75 with the decimal place 2 spaces from the right (because 100 has 2 zeros);
Answer = 0.75
Example 2: Express 3/16 as a Decimal Step 1: We have to mulitply 16 by 625 to become 10,000
Step 2: Multiply top and bottom by 625:
×625 left-up-over-arrow.gif 3 = 1,875
16 10,000 left-under-over-arrow.gif ×625 Step 3: Write down 1875 with the decimal place 4 spaces from the right (because 10,000 has 4 zeros);
Answer = 0.1875
Example 2: Express 1/3 as a Decimal Step 1: There is no way to multiply 3 to become 10 or 100 or any power of 10, but we can calculate an approximate decimal by choosing to multiply by, say, 333
Step 2: Multiply top and bottom by 333:
×333 left-up-over-arrow.gif 1 = 333
3 999 left-under-over-arrow.gif ×333 Step 3: Now, 999 is nearly 1,000, so let us write down 333 with the decimal place 3 spaces from the right (because 1,000 has 3 zeros):
Answer = 0.333 (accurate to only 3 decimal places !
Sep 22, 2009 | Black & Decker Juicers
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
Sep 22, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments BA-II Plus Calculator Logo
80 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
