Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Bissell Big Green Machine Model 1672 will not pump cleaning liquid
I have a 12 year old Bissell Big Green Machine Model 1672. The pump appears to be siezed. I've noted where others with similar problems have opened their units, turned the pump shaft a few revolutions by hand or with a tool and were able to get back in operation. Can't figure out how to open the thing. Any ideas? Many Thanks!
Have a Bissell Big Green 1672, the older canister model. Went crazy trying to figure out how to get to the pump. Finally figured it out. The top green "shell" covers the motor & pump and is separate from the "grey" plastic housing. Using a screw driver, insert it between the small gap between the top "shell" and the housing. If you look at it with it laying down on the top, you will see the small 1/4" gap. Gently pry in between the two and work your way around. It will start to lift up and then you can easily work your way around and it will pop off exposing the motor and pump. Note that the wires to the on/off & pump switches will sill be attached to the top shell. If you take them off note where they came from and make sure they are all on when you put the top back on. I have had my Green Machine for years, what a work horse! To bad they don't make them anymore, the new ones that replaced them just don't have the same durability and power as the older Green Machines.
Posted on Mar 11, 2009
    President:
  • 1,673 Answers
You have to take out the screws from the top, there are 3 on each side, then it will pull off, but the only way to correctly fix a seized pump is to replace it, It may run for away, but will just resize again. When you re-install the top housing, put the auto-mix know on the water only, and make sure the piston goes into the slot and that all lines are in correct position so as not to get crimped when you screw it back down.
Posted on Jan 06, 2008
Buy big green canister 1672 or 1672H wet/dry vacuum
Hi Anthony: This model is no longer available from Bissell in Canada. It is however still listed as available from the Bissell US website and can be ordered online. If you are looking to order this model and you are not in the US, you might check the Bissell site for other countries by changing the country on the top right hand corner of the web page.
Some replacement parts are also listed as available on the Bissell US website; including the canister itself.
If you require further assistance please do not hesitate to reply with your questions.
Thank you for using FixYa!
Dec 27, 2011 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Hi my mum bought a bissell big green clean mashine about 2 years ago and never used it because she cant find how to out together , instruction manual could you help please
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Aug 12, 2010 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Hello i am having problems finding the manual on this product..i have a old fashion type canister model no 1630-5..can;'t find it on here..but the 1672 types of hoses are the same..i got this from my...
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
Jul 01, 2010 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Pump needs replacing
I have the Bissell Big Green model 1672 and have used it for many years. Recently, the fan or suction blower began to emit a burnt smell so I shut it off. I had difficulty figuring out how to dissemble the top motor unit. Here is what I found.
Don't pry up on the very top disk, which is an air outlet. It will only break off and won't allow access to anything. If you do break it off, drill holes through the four posts and use stainless steel screws to re-attach the disk to the plastic posts it sits on.
Now, beneath the air outlet is the rest of the motor unit. The motor unit consists of three pieces. The bottom piece is the lid to the waste water receptacle. It is concave pointing down (lid shaped). The top piece is the domed lid for the motor unit. The middle piece is a flat plate between the other two pieces. The top of the flat plate (inside the unit) has mountings for the suction fan and the pump.
The flat plate is bolted to the bottom piece and the top piece (domed lid) is simply snapped down to the flat plate. If you take a flashlight and look inside the area where the AC cord is stored, you can see that the domed lid is a distinct piece from the flat plate. The model 1672 and 1680 (or 1680-3 if you wish) are nearly identilcal.
To access the internal parts in the motor unit, you cannot pry between bottom piece and the the flat plate because they are bolted together. But you can remove the top domed lid. To remove the domed lid, position the motor unit in front of you with the switches at 9 o-clock. Three snap-downs which attach the domed lid to the flat plate are at 1 o'clock, 2:30, and 7 o'clock. Wedge a flat bladed screwdriver or pocketknife between the edge of the domed lid and the flat plate at those locations and the lever the domed lid out and then up. The domed lid will separate from the bolted-together flat plate and bottom piece.
Wiring from the switches remain attached to to the electrical components. You will see that the AC cord has white, black, and green wires. The green ground wire connects to the fan ground at the 9 o'clock position. The white power connects to upper connector on the pump and also to the fan at the 7:30 position. Black feeds both switches on model 1672 and then a black wire runs from the correct switch to the bottom connector on the pump or to the connector on the fan at the 1:30 position.
Model 1680 has a third switch which feeds power to the floor sweeper. It has its own connection to the green ground and white power and goes through the third switch to connect to black.
If you need to replace the pump or the fan, shop around carefully. The pump, for example, can be found for $30 plus shipping2_bing.gif, but some will want to charge you $80.
Feb 15, 2010 | Bissell 1672 BIGgreen Wet/Dry Vacuum
I need instruction booklet for bissell big green model 1686
Hi ps_stevens,
There is no manual for your model, but i have a manual for model 1672 check the below link many be helpful for you:
http://www.bissell.com/images/UserGuides/1672.pdf
Regards
R.K.
Oct 22, 2009 | Bissell 1699 ProHeat Clear View Upright...
Just got this one at a garage sale and do not know
CLICK HERE for the user guide in PDF format
This should cover everything you want to know.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 04, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Open power unit on Bissell 1672
Jan 08, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Manual for Bissell 1672 BIGgreen Wet/Dry Vacuum
You can download the Manual at http://www.bissell.com/images/UserGuides/1672.pdf, I hope this helps.
Aug 06, 2008 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
2,610 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
