Question about Sharp Microwave Ovens
My Sharp Carousel R405HW is not producing heat but all the other functions are working and it is on high heat power level wise.
    Sergeant:
  • 197 Answers
Sounds like the magnetron or transformer may have died, take to approved dealer, if worth it!
Posted on Sep 29, 2009
Sharp Carousel microwave - 1200 watts - Model R530EKT - caught on fire while using
you must carefully and read your instr. manual if some material inside the microwave can be produce fire. Otherwise the microwave can be old and the electronic component deterioring and cause exploding.Some time the material inside from the microwaves, is corroded, and the irradiation can be produce Fire. Tes the indication given.
God bless you
Oct 01, 2012 | Sharp R-510HW Microwave Oven
Sharp R-340H Microwave has power but does not heat food. Carousel working.
The magnetron is the likely problem, "heats food" the other two items to check is the high voltage capacitor and diode. It usually is cheaper to replace.
Apr 06, 2011 | Sharp Microwave Ovens
Sharp r-930ak microwave stopped working
either the high voltage side has gone done or pcb is not putting out the output.
Sep 14, 2009 | Sharp R-930AK Convection/Microwave Oven
Sharp carousel microwave model # 508ak has power but does not heat food when you press the start button. thanks in advance!
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
Jul 11, 2009 | Sharp R-510HW Microwave Oven
It's not getting heat and LCD looks like there's water inside.
On most Sharp Carousel Microwaves, the display stops working after time. As for the not getting any heat, the magnetron or the high voltage transformer may not be working.
Jul 04, 2009 | Sharp R-510HW Microwave Oven
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
May 12, 2009 | Microwave Ovens
Full exact diagram of parts for sharp carousel II convention micr
Unit heat syncs and rotor is not working due to high voltage
Mar 07, 2009 | Sharp Microwave Ovens
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
The Microwave is a Sharp Smart Carousel Model R-2130JS The food contains get hot but not the food
This model uses an inverter to product high voltage.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Sharp-authorized servicer.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 05, 2008 | Microwave Ovens
Sharp carousel II microwave/convection oven
The question is... Do you want to put money on a 18year MW, or put it towards a new one? I must admit I love the SHARP Combo MW Convection ovens. I own two. One is almost 25years old. The mechanical Timer Type, but they work great and I can maintain them with 30years ef exrerience. I am now retired.
It does sound like the Magnetronhas broken down, however it could be other things in the Secondary (High Voltage Side). The High Voltage Side is made up of the Secondary HV side of the High Voltage Transformer, A High Voltage Diode, a High Voltage Capacitor, and the Magnetron. The High Voltage Side is DANGEROUS, and CAUTION should be taken to protect yourself against EXTREME HIGH VOLTAGE. unplug from power and DISCHARGE High Voltage Capaciton to frame GROUND before touching anything!!!!
Jan 29, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
