Question about Lexmark X7550 InkJet Printer
My lexmark X7550 only prints small print. - Lexmark X7550 InkJet Printer
PABLOCSA
  • 1124 Answers
SOURCE: I can not get my
If you already have your printer installed do this:
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Posted on Nov 12, 2008
  • 2692 Answers
SOURCE: printing w.lexmark e232 font way too small
I believe LEXMARK has upgraded the software for you printer with a new VISTA driver. Disconnect the printer, uninstall the software . Reinstall the software for you model from theLEXMARK  link I have provided you below:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Feb 08, 2009
vortash
  • 431 Answers
SOURCE: printing issue
Check your fonts on the print command page visible everytime you start to print .. before you click ok check it is the size you want .. go to preview page and see if it has all the things within the parrameters you require ........ vortash
you could also try cleaning your head cartrige with a fine cloth and some cd cleaning fluid on the rag , dont rub hard as this might damage the foil on the head .
Posted on May 02, 2009
  • 684 Answers
SOURCE: Bold lines on Fax and Scan
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Posted on May 27, 2009
SOURCE: Can not use Lexmark x7550 after enabling WPA2 on the wireless network
I get the same problem with my Lexmark x4580 when I enable WPA2. However, WPA AES with a pre-shared key (ASCII) works fine.
Posted on Mar 29, 2010
My x7550 wont print pictures.....says its printing and ink level goes down, but photo paper comes out blank
It could be that your cartridges need some cleaning. From the printer operator panel, scroll to the Maintenance menu and select Clean Cartridges. Your printer will then print a test page forcing ink through the cartridges nozzles and clean them.
After doing the clean cartridge function, try to print another photo to determine if the problem is fixed.
Hope this helps.
Apr 30, 2012 | Lexmark X7550 InkJet Printer
Lexmark x7550 won't communicate with computer to scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ngaKcu. Select your operating system, download and execute the file.
Oct 19, 2011 | Lexmark X7550 InkJet Printer
Can a lexmark x7550 print to a mac?
Yes, the Lexmark X7550 support Mac & Windows too. You have to install the respective drivers versions for your Mac versions.
You can download the Mac OS versions drivers @ http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X7550#2
Make your Mac OS selections "Change OS" to proceed in downloading the correct Mac drivers for your System.
Hope it helps.
Jun 24, 2011 | Lexmark X7550 InkJet Printer
Cannot print to lexmark x7550 printer. it seems that printer is able to scan but not able to print. already installed the software, but when connecting the printer to the computer with windows 7, it...
Try to use the Windows 7 driver from the Lexmark website. Uninstall the existing driver from your computer first. How to Uninstall Lexmark Printers. Reboot pc when prompted. Then, check if your Windows 7 is running on 32-bit or 64-bit system type by going to the Start menu > right-click on Computer > Properties. Take note of the System Type.
To reinstall the driver, use the following links below: - Lexmark X7550 Driver for Windows 7 32-bit - Lexmark X7550 Driver for Windows 7 64-bit
May 25, 2011 | Lexmark X7550 InkJet Printer
The printer will not cancel a print
cancel via printer options in windows.. and turn off the printer... turn it on again.. hopefully it will solve your problem
Mar 01, 2011 | Lexmark X7550 InkJet Printer
I have a LexMark x7550 all-in-one printer, model:4429-W22, serial #: 01360113314 2007/09. Printer will not print internet download or regular documents. I unpluged the printer and rechecked connections,...
Please go to run and enter "devmgmt.msc" you will get device manager, Remove all of the Universal Serial Bus from the device manager and click on Scan for hardware changes. It will install all of the USB drivers. After that connect the all in on printer and install the software properly.
Aug 07, 2010 | Lexmark X7550 InkJet Printer
I want to know what ink does it need. What to buy for my Lexmark X7500 series
I have the same printer and I go to Office Depot, the cheapest around, and you get rewards. Lexmark 41 Print Cartridge is the color and Lexmark 42 Print cartridge is the black.
May 15, 2010 | Lexmark X7550 InkJet Printer
I have a X7550 printer and I can't get it to print
please confirm which OS is on your laptop, and run the driver for that OS, you may read this up
http://www.lexmark.com/publications/eng/x7500/index.html
Mar 16, 2010 | Office Equipment & Supplies
I have a lexmak x75 printer and it wont print only scans
go to the lexmak website download th newest software for printing do this and send me what happened in my mail www.m-o-m@hotmail.com
Aug 17, 2009 | Lexmark X7550 InkJet Printer
Lexmark X7550 InkJet Printer Logo
16 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
