Question about Sport & Outdoor - Others
Almost new air mattress has a hole in seam. No
Almost new air mattress has a hole in seam. No receipt only used 4 times. What can I do?
    Problem Solver:
  • 10 Answers
Contact local vehicle trailer repair garage.they will probably have rubberised repair patches that they use on curtain sided trailers.it should do the job.
Posted on Sep 29, 2009
Can anyone supply me with a contact number or email for Embark. I bought an air mattress from Target and have exchanged it 4 times already because the seam comes apart. Cannot find any contact 411.
embark headquarters are at 73 jawatte road colombo, sri lanka
with that many returns of faulty beds , I would have thought that after the second return you would have got a refund and bought something better elsewhere
contacting the office will be pointless as the company doesn't care about the quality of the product
Feb 13, 2016 | Camping, Backpacking & Hiking
I got a Swiss gear queen size bed ans it's got a hole right on t he top of the bed on a seam, the patch that came with it is not working in sealing the hole, what else can I use?
You could try some seam weald glue.
But when these leak from a join, it can be very very hard to reseal them.
You could try a hot soldering iron, carefully try to reseal.
But to be honest it may be easier to purchase new.
May 12, 2014 | Swiss Gear SwissGear Queen Raised Double...
Do air mattresses deflate throughout the night?
When air mattresses first came out, deflating was a major issue. In the last ten years or so, all air mattresses built don't have that problem unless they have a puncture somewhere.
Feb 20, 2013 | Camping, Backpacking & Hiking
It leaks air
Can I loan you my nephew? He's FULL of hot air, and would be good to have around. "Hey Brandon, air mattress needs air again."
I suspect your problem is in the inlet valve itself.
Is it not seating all the way? Droplets of water applied to it, is air leaking out?
Is there a manufacturer defect on the valve itself, or the valve receptacle it goes in?
Has a pinhole developed in the mattress? Somewhere along a seam?
If so toss it. I am not aware of any patch kit that will help a problem such as this one.
Just my 2cents
Regards,
joecoolvette
Feb 11, 2013 | Camping, Backpacking & Hiking
A few years ago I purchased a SlumberAir Mattress system by La-Z-Boy and I love it. It is the bed I sleep in every night, but I've run into problems with the air mattress. It seems after three m
You should check the coil mattress cover. Feel around to make sure nothing is puncturing the bladder. It is not normal for them to fail like that. When you deflate it, you must make sure all of the air is out of the bladder before folding the unit back into the sofa. If you don't, you make end up with a problem at the seams.
Sep 16, 2012 | la-z-boy.com
I just found a small hole in my air mattress. How do I properly fix it?
When you bought your air mattress you will have most likely received a patch kit. If not, you can purchase one at most stores selling mattresses/camping gear. Simply follow the instructions on the patch kit - make sure to cut a patch slightly larger than the size of the hole. Allow 24 for the glue to dry before re-inflating your air mattress.
Jul 31, 2012 | Camping, Backpacking & Hiking
Can I use my air mattress outdoors?
Yes you can. Most air mattresses are designed for outdoor use. I would suggest placing the mattress on a tarp while sleeping to avoid puncture holes from twigs and stones on the ground.
Jul 25, 2012 | Furniture
What can I use to repair a small hole in my coleman air mattress?
Hi rh57...
I will recommend that you use some contact cement, and a piece of thin plastic like a plastic drop cloth, shower curtain, etc.
Cut the plastic piece that will be using as your patch about 1" X 1" square.
Locate the hole in the air mattress, deflate air mattress, apply contact cement lightly to the air mattress approximatly 1" X 1" and the piece of thin plastic material you will be using as the patch over both entire surfaces of the patch and mattress...let it all dry about 20 mins.
After it is dry then apply the patch to the hole in the mattress, apply a weight to the top of the patch, let sit about half an hour and you are done
Hole fixed
Please take time to rate me thumbs up
Sep 14, 2011 | Garden
I lost my manual, I need to know how to transform the crib into a toddler bed
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
mkd123_2.jpgGraco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
Jan 23, 2011 | Simplicity for Children 4-in-1 Convertible...
Sport & Outdoor - Others Logo
83 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
