Question about Amana Refrigerators
Arb2205cw, bottom freezer: refrigerator is
Amana Arb2205cw, bottom freezer: refrigerator is freezing food. I set both the temperature dials (fridge and freezer) to the minimum setting and still the fridge is freezing food. When I turn the freezer dial to off, the fridge stops working as expected. Also the fridge is not continuously running and takes a brake from time to time.
The only "anomaly" we've seen is that there is frozen air that is coming out of the fridge traps. We don't recall seeing that before.
We called a technician who seemed to be drunk and that for a 100$ "inspection fee" looked at the fridge for 5 minutes and decided that the freezer's control was bad. But he said if this isn't the real issue we have to pay him again and again until it is fixed.
Could the issue really be the freezer's control? As mentioned earlier it does turn off the fridge and turn it back on when I put it at various settings.
If not, what could be the issue?
Thanks.
fridgetech
  • 473 Answers
SOURCE: Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Posted on Oct 10, 2007
MNTECH
  • 1543 Answers
SOURCE: GE refrigerator 12 years old runs continuously, exterior warm
Probably not. Newer (and I mean under 15 years old or so) refrigerators may run more % of the time than older units, but are using far less energy while running, so total energy consumption is actually less. The newest energy star models often use less electricity than a single incandescent light bulb uses if left on 24/7. If your run times are noticeably longer just recently, and there have been no other significant changes to account for it (like more and / or longer door openings or a warmer ambient temp., etc.) then you may have caught a defrost problem or bad door gasket problem early. The warm temp on the outer case near the freezer is to prevent condensation from forming in those areas, and is normal. (as a matter of fact, older refrigs often used low wattage electric heaters for that task, almost all newer units use waste heat from the cooling system to accomplish that task) Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Posted on Feb 16, 2009
wheelshot
  • 102 Answers
SOURCE: Subzero 590: freezer works, refrigerator not cooling
This is a Sub Zero and many technicians do not realize that these units most all run on 2 separate systems. 2 cold controls 2 compressors 2 evaporators. They share a condenser and condenser fan motor. What you are describing is most likely a bad cold control. It is pretty common for these to get some age and go bad. If you are very savvy with repairs yourself then if you access the compressor area and feel that the compressor on the right is cool and the compressor on the left is warm then you know that the ref. compressor has not been running. UNPLUG THE UNIT OR CUT THE BREAKER OFF. Remove the shelving from the fresh food section and the cover to the lights and the panel below the lights and lean the back panel forward to access the cold control. You will see 3 wires to the cold control. The green wire is the ground wire of corse. Unplug the other 2 wires remembering their location on the control unit. Take a jumper wire and jump these 2 wires. If when you power the unit up the right side compressor comes on then you know that your fresh food cold control is bad. Replace fresh food cold control.
Posted on Apr 11, 2009
projdoc
  • 2237 Answers
SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Posted on Aug 28, 2009
SOURCE: my fridge is over cooling - now freezing food
i just want to say that i have the same fridge freezer and that is whats happening to mine. even the drinks are freezing aswell as tomatoes and any other thing that is put in there. after reading your problem im thinking maybe this is a manufacturing fault. i am about to buy an extended warrenty for mine then i can get the poeple to fix it as mine is also 3yrs old. hope that helps.
Posted on Feb 24, 2010
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Fridge is freezing everything
Check the top of the inside of the fridge. There is usually a flap door mechanism that sometimes falls off or sticks. This regulates the temp in the fridge.
Jan 29, 2014 | Amana ABB2524DE Bottom Freezer...
Our Amana bottom freezer refrigerator is too cold in the refrigerator portion. It keeps freezing all the fruits and vegetables even though the temperature is set on the warmest setting in both the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 11, 2011 | Amana ABB1927DE Bottom Freezer...
MY FRIDGE SEEMS TO FREEZE FOODS NO MATTER WHAT SHELF OR DRAWER THE FOOD IS IN
Put the duals back to factory setting. Always the middle number and it is always highlighted. If they already are then turn the fridge only down a setting. The freezer always stays at factory I think 3 or 4 on Amanas.
Jan 28, 2011 | Amana ARB190RCB Bottom Freezer...
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
How do you set the temperature of the freezer...my freezer freezes at the mid setting on the control dial.
get a thermometer and set the freezer to -18C and a fridge to +5C.
these are the optimum temperatures for keeping food.the internal knobs are for guidance once set,to adjust to seasonal changes.summer to winter.....and for when you refill
Aug 28, 2010 | Magic Chef MCBR440 Compact Refrigerator
Amana refrigerator fresh food control does not work at all
first of all, check to make sure your fan is working, also check the inside compartment for the damper should be open when your rise or lower the temperature settings on your dial. when you rise your temperature dial to 5 you should feel air flow coming out of the damper, if not check to make sure that the evaporator fan is working first, if it is than check the damper door should be open sometime this damper door gets stuck on something or they break off.
Dec 26, 2008 | Amana ABB1927DE Bottom Freezer...
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
69 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
