Question about Dell Inspiron 2200 PC Notebook
Recalibrate battery then it reboots and message reads f1 to continue and goes through the same cycle never boots up
  • IQUIT May 11, 2010
    If battery is removed, is there any change?
  • 3,940 Answers
Remove the battery, run the system on AC alone and see if anything changes. You can also try booting to the BIOS and resetting default settings.
If system boots normal with battery removed, then replace the battery.
Posted on Sep 30, 2009
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
Jul 29, 2012 | Dell OptiPlex GX260 PC Desktop
My Dell Inspiron 1200 screen is saying recalibrate the battery.Once i have done this the screen goes blank and does not reboot
Have you tried to turn on the computer without the battery, it could be a shorted (bad) battery... they can prevent the notebook to boot, if the notebook boot's without the battery you need to replace the battery...
Mar 16, 2011 | Dell Inspiron 1200 Notebook
Had plug and play config f1 f2 error message problem. replaced battery message went away but can not boot up
boot to BIOS Press ALT+E (1 Beep) Press ALT+F (1 Beep) Press ALT+B (Reboot)
see what happens
Dec 14, 2009 | Dell Dimension 8200 PC Desktop
Cant get 4600i started. powers up but will not get past intro screen. screen shows F1 to continue and when i press F1 it tells me to press it again to retry reboot, F2 for setup options.
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
Itronix VR-1 Go Book Fan Failure message
After bios upgrade had same problem. DISCONNECT AC POWER PULLED BATTERY FOR AT LEAST 5 MINUTES THEN REATTACHED BATTERY AND FAN WORKED ON NEXT RESTART. Also make sure boot menu ( tap F12 at start-up) is set to boot from Hard Drive. I also started on battery power with no ac adapter.
Apr 17, 2009 | Computers & Internet
945GZT M V1.0
David i take it you mean you played with the bios screen ?
if so you can remove the power cord then open the side of the computer and remove the bios battery (big silver watch type battery on the mother board) leave it for around 15 mins replace the battery then the power cord you will find an error screen when you switch on.
its normally f1 to load default settings and continue the boot
that should solve it
Mar 22, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Dell Dimension 8300
Here's Dell's page for changing the battery for a Dimension 8300:
http://support.dell.com/support/edocs/systems/dim8300/sm/battery.htm
Nov 01, 2007 | Dell Dimension 4600 PC Desktop
Dell Inspiron 2200 PC Notebook Logo
290 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
