Question about Dell 1815dn All-In-One Laser Printer
My machine has an error message "Internal Error Power On/Off". I tried turning the machine off and on but the message remains. Also gives me the following number: 40b 76624 3T 915 rip. I hope the rip doesn't mean rest in peace
  • xtramile Sep 29, 2009
    YES! I have my printer back up and running. Thank you so much!
    Guru:
  • 1,326 Answers
Try unplugging it for 5 minutes to reset the machine. If not you have a circuit board going bad. Sometimes the computer just hiccups and has to be reset but when it happens continuousely its usually a circuit board going/gone bad
Posted on Sep 29, 2009
Sir, i have hp laserjet colour printer CP5225, having error 55.0601. Kindly give me online solution
this all i manage to find for hope it helps
55.x Error
Error Message
55.X Error
Turn off then on
Description
The printer has experienced an internal error. The printer may experience one of the following errors:
55.0 DC controller communication error
55.0601 DC controller NVRAM data error
55.0602 DC controller NVRAM access error
55.1 DC controller memory error
Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the printer to initialize.
If a surge protector is used, remove it. Plug the printer directly into the wall socket. Use the power switch to turn on the printer.
If the message persists, contact HP support.
You need to first check the connection between the dc controller and the formatter and if the connection is fine you need to replace the dc controller.
Dec 22, 2010 | Office Equipment & Supplies
Trying to send a fax and it keeps giving me a error 0503
If you are trying to send a fax message using your desktop computer and it shows an error 0503, you just need to turn off both devices your modem and the computer. Now if you have an internal modem so you just need to turn off your computer for atleast 5 minutes to drain the power. Then you can try to refax your message.
Sep 09, 2010 | Computers & Internet
I have a Hp color laser jet printer it is giving me an error message 55.1 turn off what does this mean I have tried turning off
Here is what HP says... Error message55.1 Error DescriptionDC controller error. The device has experienced an internal hardware error. Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.You could have a bad power outlet. try another one.
Apr 15, 2010 | HP Color LaserJet 2600n Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
SR-16 gives message "ERROR: 01" when powering up
You likely have lost the internal memory data. This can be due to a power surge or that the internal battery has been depleted. The battery may need to be replaced.
You should reset the unit and reload the data, The manual is available online. Search Google for it.
The manual STRESSES the importance of backing up the data.
If you don'thave the backup, you MAY need to find another SR-16 owner to clone the data from.
Jul 01, 2009 | Alesis Sr 16 Stereo Drum Machine
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Sep 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Breadman Ultimate ¨HI¨ Error
If there was a power outage one of the internal circuits could be messed up giving you this error. You may want to contact the maker and arrange for repair service or diagnostics in house.
Nov 26, 2007 | Breadman TR2200C Ultimate Bread Maker
"Internal memory is full"
This error message means that there is no space remaining in the internal memory. Turn off the camera and insert a memory card, or transfer or delete pictures
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Dell 1815dn All-In-One Laser Printer Logo
262 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
