Question about Honeywell Programmable Thermostat Heater
My honeywell theremostat clicks when the room is at the right temperature, but it doesnt matter if i have it on 10 or 25 my radiators are piping hot, why is this
  • 24 Answers
Most thermostats have relays built into them and will clickwhen turning off or on
Posted on Sep 30, 2009
My thermostat for electric baseboard is a double pole Honeywell that turns the heater on no matter what temp.you set it on
Suspect that the thermostat is defective. The link to the manual is included. You should feel the click as you rotate the knob at or near the room ambient temperature cycling the power on and off.
Hope this Helps?
http://www.homedepot.com/catalog/pdfimages/88/88087443-e3d9-448b-b370-daad984ccb47.pdf
Nov 21, 2016 | Honeywell Heating & Cooling
Make : Weil-McLain Model : CG-5-SPDN Series 12 I have the above mentioned boiler which is located on the 1st level of a three story one family house, the area where the boiler is located is insulated.
You don't have an optimum distribution of steam in your house. Try closing a little bit the valves supplying the heaters in the lower floors. Close a little bit more until you get the desired balance.
Nov 06, 2012 | Heating & Cooling
Am going away and would like to know what level to turn the radiators down to, on the westtherm radiator valves it goes from * to 1 - 5.. Would the * setting be okay?
I assume you want to save on heating costs and at the same time keep the pipes from freezing in your absence. 50 degrees is the normal temperature you want to maintain in this case. However, I am unable to tell you exactly which setting would maintain that temperature. So try closing the door to one room that you infrequently use, put a thermometer in that room and turn the radiator down to the first setting. After several hours, check the room temp. If it's 50 degrees, you've got it right. If it's below 50, turn it up a notch and check it again in an hour. Remember, night time air temperatures are generally colder than daytime temps.
Feb 08, 2011 | Heating & Cooling
I have a cm921 thermostat with the correct batteries showing full charge. Yet the battery light is flashing and says battery low. Also displayed room temperature is a lot higher than the actual room...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm III Lowest temperature setting is 45F Any way of getting it lower thanks
If you are successful in setting it lower , you will end up with frozen pipes and large plumbing bills. Since the internal walls of a building can be as much as 20 degrees lower, that the room.
And the location of the thermostat, may be even warmer, that that of the areas where the plumbing is.
Now what is your reason for wanting the thermostat operate at a lower temperature?
Jan 31, 2010 | Honeywell Heating & Cooling
Unlock a Honeywell Thermostat
That is correct hold the override button and the + button for a few seconds. Then you will see it flash and you can change the temperature then
May 28, 2009 | Honeywell Electronic Programmable...
TOO HOT
not sure how you system is set up but it almost sounds like you have a maintain system or a stuck thermostat to stop the heat if you dont make hot water with this boiler turn off the switch on boiler till you can get service person in if you can tell me more about the way your system is set up i could help more.if you want to see if its a problem with thermostat pull red wire from subbase
May 02, 2009 | Honeywell Electronic Programmable...
No heat in zone with Honeywell rth230B
It is not your thermostat, it is an airbound zone. The gurgly noise you heard was that water and air flowing through the radiator. The zone needs to be purged either at the boiler, or through vents on the radiator. Hope this helps
Nov 01, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
