Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon pixma mp800 puts a black stripe on back of page - goes away after I clean the bottom plate (control panel, right-click on mp800, go to Maintenance) but then after the printer sits for an hour or so, the stripe is back - a LOT of ink! I have read on the discussion boards about the ink absorber, but the problem STARTS with too much ink coming from the cartridge in the first place. Any help is greatly appreciated
3 Suggested Answers
  • 286 Answers
SOURCE: PIXMA MP830 is Printing Stripes
Really sounds like the black portion of your print head is clogged. Do the "deep clean" on the black head a couple of times. If it's still not working you may have either a bad head or a clogged purge unit.
Clogged purge units are very common on inkjets.
You can try soaking the bottom of the head on a very wet paper towel overnight. Retry using the head the next day and see if the black is working (print more text documents).
If that doesn't work, you'll have to find a way to check the purge unit/capping assembly under the home position of the head. It will require taking the unit apart and removing the purge unit and cleaning it. Make sure the two tubes are not clogged, Use a piece of wire and feed it through the tubes to try and remove any dried ink.
If you're not into trying to take the unit apart, it's time for a service shop or a replacement printer
Posted on Nov 07, 2008
F Victor man
  • 821 Answers
SOURCE: Canon Pixma MP800 Prints a
I have seen this before but it has not caused the black to run out quickly. if you look into the machine you will see at one end of the platen roller it will be swimming in ink. As the paper passes over the roller it will deposit ink to the back of the paper. now why is the ink getting there? Well its just possible that air hole in the cartridge is blocked but you say you have replaced the cartridge. Ah but with what? are you using recycled cartridges? they may be filled with ink and not dye which is what originals use. Dye is much thicker than ink and ink maybe leaking from the cartridge. The seal in the carriage may not be making a clean contact with the base of the black cartridge causing it to leak when the carriage is moving. Check those out and repost if still having the problem.
Good luck
Posted on May 16, 2011
Solid black ink line, top to bottom, on back of every printed page
The possibility of the printer roller is dirty. To clean the roller, do
1. Press the START
2. Select Printers and Faxes
3. Right click Canon PIXMA MP530, select Printing Preferences
4. Select Maintenance
5. Select Roller cleaning, and Bottom plate cleaning
Nov 02, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon Pixma MP800 Prints a 1/4" black stripe on back of page. Is emptying the large PGI-5 cartridge in record time. Have replaced cartridge, run cleaning and maintenance routines. Cleaned bottom...
Good luck
May 16, 2011 | Canon Office Equipment & Supplies
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
How to resolve printer not printing black when printing from computer but prints when photocopying.
It sounds like an issue with your "printer settings" on your computer. Go to control panel,printers and faxes,right click,then printing preferences, this should take you where you want to go.
Dec 12, 2010 | Canon Pixma MP800 All-In-One InkJet...
I am getting black streaks on the back of the pages i print
Go into the driver from the control panel and do a bottom plate cleaning from the maintenance tab
Aug 01, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon MP500 printer
We have the same problem. I removed the cartridges, then removed the print head. There was lots of ink gunk on the print head. I cleaned it and the problem disappeared completely for a few days but is now back. I suspect the print head needs to be replaced. Still working on it.
Apr 11, 2008 | Canon Pixma MP500 All-In-One InkJet...
All colours are faint. The black comes out grey.
hi clean your cartridges clean your cartridge head nozal with the printer software goto to start-> settings->printers and faxes-> select your printer->right click->properties->tools-> find options like clean cart or nozals.
check printer settings for best ,normal,or draft set as best and try. may helpful.
Mar 03, 2008 | Canon Pixma MP800 All-In-One InkJet...
Black Smudges of the First Copy. Canon pixma ip 3000.
try cleaning all the runners that the paper uses on the printer. Clean the dabbing pads inside the printer too.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
120 people viewed this question
old marine
old marine
