Question about Dryers
Drum turns, poweris present, does not heat
Dryer is around 1 year old. sits next to the exhust vent with no kinks in the exhaust hose. had just finished a couple loads, then the dryer just quit heating. the dryer is apart i just need to know how to test thermostats.
    Genius:
  • 1,466 Answers
Some stats are classed one shot and therfore non resettable,,You can check them with a multimeter is should read or sound when connected acorss. Failing that try a battery from a torch or alike across the stat one end small bulb /lamp the other if it light circuit ok if not buy a new stat/make sure you clean filters anyway...Good luck
Posted on Sep 29, 2009
  • 6,784 Answers
HI. To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
  • Michael Masters
    Michael Masters Sep 29, 2009
    Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Samsung#DV448AGW/XAA check filter light on
Hello. #1-Use a vacuum cleaner with hose attached and vac the drum vent screen inside the drum. #2-disconnect AC power(unplug or switch off 220volt breaker) carefully remove hose from air duck of dryer and vac inside of dryer. Vac the hose and exhaust port. Reattach hose, reconnect AC power and test operation. #3-Problem still present the exhaust sensor or the (most likely) the exhaust fan not working properly. Good Luck!
Feb 28, 2012 | Samsung DV448AGE Gas Dryer
My Maytag electric dryer will not dry clothes. In reading solutions, it said to check to see if the exhaust vent is clogged. I'm afraid if I take it apart and not put it back together correctly, it...
If the heat turns on and the drum is turning them you need to make sure that it has a good air flow. You will probably have to buy a new dryer vent hose. Just follow the directions.
Sep 23, 2011 | Dryers
My Maytag dryer is 2 1/2 years old. I believe the belt is broken on my dryer. My gas dryer heats up and the drum turns, however,it takes a long time to dry my clother. Would this be the belt and is...
2 years parts and 1 year labor. Warranty work usually requires a sales receipt.
The only way that the belt would affect the dry time is if it is very loose.
First look for a clog anywhere from the filter to the dryer vent cap outside. The dryer vent hose should be clean (very little lint present). Any obstruction like a kink in flexible vent line (which shouldn't be used) will slow things down.
If it's none of these things, the thermostat or gas valve may be bad.
Jan 07, 2011 | Maytag MDG2706A Gas Dryer
Dryer shuts off after 5 minutes.hose is clear..appears to get hot...also hot to touch on top
If your dryer is still heating, but your clothes aren't drying properly, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
In severe cases of dryer vent clogging, you may experience condensation inside the drum and/or vent exhaust. The dryer exhausts warm, moist air. If the heat and moisture have no where to go, it will condensate inside the drum and exhaust vent. Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This eventually will lead to component failures and is the source of many fire hazards.
There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, this usually a good sign the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
NOTE: If you have already determined the exhaust ventilation is clear from the point where it leaves the back of the dryer to the point where it exits your home, you need to check the vent hose run to ensure there are no excessive bends or kinks that can be causing choke points that restrict air flow. If the vent line checks ok, then you need to inspect your blower fan housing inside the dryer to ensure it is not clogged. If you have any questions, please post back with your COMPLETE MODEL NUMBER and let me know. I hope you find this information helpful.
Dec 23, 2010 | Roper Dryers
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer is not drying. Lint is not collecting on
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted through the dryer vent exhaust ducting along with the moisture from your clothing as it dries. If the exhaust vent remains unobstructed, all the air and lint will be blown out the end of the dryer vent exhaust.
However, if the air meets any resistance from kinks, excessive bends, or sags, moisture will build up inside the dryer vent exhaust causing the lint to stick to the interior walls of the vent hose. Over time this lint builds up and forms a clog. With a clog comes condensation and longer dry times. The dryer will continue to run inefficiently and cause the heating circuits to work harder and overheat. This will eventually lead to a failure of the heating circuits. If you are seeing condensation inside the dryer, it is strongly recommended the you inspect and clean the dryer exhaust vent hose. You should repeat this a couple of times a year to ensure it remains obstruction free.
The most frequent causes of dryer vent clogs comes from the following:
1. Ducting that runs in an upward direction in homes that have an attic exhaust. This is a stupid design that gravity will always win. When the dryer shuts offf, anything left in the vent will fall down the ducting to the base of the wall and accumulate. Over time, this forms a clog.
2. Ducting that runs under the home in a crawl space. If not correctly hung from the rafters, the ducting will develop sags causing choke points where lint can accumulate. Leaving it on the ground is not the answer, either. This gives opportunity for rodents to possibly chew through it. This will cause leaks which exhausts warm moist air under your home resulting in mold and mildew.
3. Using plastic dryer vent hose. This type of hose is not recommended because it kinks easily and can get crushed, causing an obstruction where lint can clog. Rodents can also chew through it easily. Pushing the dryer up against the wall and crushing the hose is a common cause. Use the semi-rigid metal type ducting that resists crushing, kinks and rodent infestation.
4. Rodents. Mice love lint. If given the access to it, they will build inside the dryer vent hose which provides a nice warm place to live with lots of bedding material. Make sure you exhaust vent on the exterior of your home is about 12 inches from the ground.
5. Exhaust vent screens. I know there are many types of exhaust vents on the market that you can purchase that have screens on them to prevent birds and rodents from entering them. The screen can actually become and obstruction, though. The smaller the opening, the more resistance the blower fan meets and lint will clog at the end of the exhaust. If you chose to use a protected exhaust vent, the ones with louvers work better. You will still need to periodically check the ensure it does not become clogged.
6. Excessively long vent hose. The rule of thumb when it comes to dryer vent ducting is: The SHORTER and STRAIGHTER the run, the BETTER. Excessively long dryer vent hoses will clog due to the fact that the blower fan is not able to push all the air and lint all the way to the exhaust.
7. Kinked, Excessively Bent, or Crushed vent hoses. If the vent has any choke points due to kinks, bends, or gets crushed behind the dryer, you will develop ponts where the exhaust vent will clog.
The following link may also help in providing some basic guidance on how to install dryer vent hose:
http://www.fixya.com/support/r389357-dryer_ducting_installation_tips
I know it may seem that I'm beating this point to death, but it is important to provide good air flow for your dryer. The number one cause of dryer failures and house fires comes from poorly maintained and poorly installed ventilation ducting.
If you have any questions, please let me know. I hope you find this information helpful.
Sep 07, 2009 | Dryers
Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
Aug 09, 2009 | Kenmore 600 7965 Dryer
HE4 propane dryer wont heat, how do I get the codes display?
Sounds like a clogged exhaust duct or vent. If not venting properly, most dryers will turn the heat off, for safety reasons.
Go for the easy fix first. Before removing your exhaust ducts from the dryer, look for any kinks that may cause blockage. Clean out the duct of any lint or water that may have accumulated. Check the vent on the outside of the house and make sure that its not clogged and opening properly.
Jun 05, 2009 | Kenmore Elite HE4 Electric Dryer
Heat not confined to tub
You should check the drum seal, front and rear. Also important is the dryer venting. If the vent is restricted by a kinked vent hose or run an excessive distance as is the case in most apartment homes and conduminums
Mar 11, 2009 | Dryers
Clothes don't get dry
ckd rear vent hose be sure it is not flat and kinked try a load with vent disconnected if works ok ck vent all the way to the outside for blockage
Jun 03, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
