Question about Palm Treo 680 Smartphone
My phone stops getting signal after I Hotsync.
For a day and a half now my phone stop receiving signal so I did a soft reset and it didnt work then I did a hard reset and it worked:) then i hotsync and it went back to the way it was before, no signal. Im not sure what is causing this but it stinks. All the software i have i havent changed in awhile and its now doing this out of no where and resetting itself now and then :( i love my treo i dont want to switch it:( any suggestions you may have would be greatly appreciated. -sephra
  • 97 Answers
It is your information thats corrupt and causing the problem.....if you do the hard reset again, and manually imput your information, it should be fine.....
Posted on Jan 02, 2008
Palm centro trying to synch without being connected to PC
Hello brad_bork,
Make sure bluetooth is turned off and the usb cable is not connected. Then do the following:
•Tap the hotsync icon
•Notice the words 'Local | Modem' side by side on the screen
•Tap 'Modem'
•Select 'Standard Modem' in drop-down list
•Enter any phone number (eg. 800-525-6452 *this is a non-working number)
•Press the Home button
Now hotsync should stop trying to sync automatically. When you want to run a hotsync Tap on 'Local' in the hotsync screen.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jan 24, 2010 | Sprint Palm Centro Smartphone
I'm having the same issue with my palm centro that everyone else seems to complain about (trying to HotSynch continuously). With all of these customers experiencing the same issues, surely there should be...
Hello shalen,
•Tap 'Modem'
Have a great day,
martyshaw152
Jan 16, 2010 | Palm Treo 500 Centro
GPS signal has stopped all of a sudden.....one year old device
My Pilot GPS has the same symptom. Their tech support tells me that all Pilot GPS users have this problem. He received an email from some one of authority (within their company) this afternoon. The email blames the problem on satellite sign strength being reduced for GPS signals.
He tells me that there is suppose to be some sort of solution in place by this Sunday morning. Every Pilot owner will need to reset there system to adjust to this change .... whatever it is.
This issue is, in some way, related to changes having been made to support signal strength improvments for digital broadcast TV..... I don't
Jun 18, 2009 | Tomtom GO GPS Receiver
Caller Id stopped working
try to give it a soft reset its easy go to settings/conigurations/resotore factory defaults!! 0000 or 12345 or 8 zeros okay??
plz rate this poste
Aug 25, 2008 | Motorola Mobility SLVR L7 Cellular Phone
My cd player stopped working and then i reset it now it works and my subwoofers worked at first and then the next day they stopped? i put the wires back in and switched them around but it didnt do...
make sure the sub-woofer is selected and turned on from the receiver. Most receivers have a setting for the sub-woofer, and if you did a reset, the factory setting may be set to off.
Is this receiver a car receiver or for the home?
What model and make is it?
I can help you further if you need it, but those are two questions I would need an answer to, so I can understand the problem a little better and figure out how to turn the sub on. It is not the same for every receiver.
Dave
Jun 27, 2008 | Audio Players & Recorders
Unable to hotsync with my computer
anytime you get fatal alerts you have to do more than just push the reset button. You will have to do a soft reset or possibly a hard reset,(usually the soft reset works) Google it and you will find it is quite simple to do
Jun 17, 2008 | Palm Tungsten E Handheld
MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
Did it actually reset when you did a hard reset ..or does it stay powered up?
Dec 31, 2007 | Palm Treo 680 Smartphone
Cannot receive messages
If your phone is a prepaid service and it has run out of credit at sometime recently this may be what is causing the trouble.
these services get stopped when there is no credit and are supposed to automatically turn on when credit is reapplied but sometimes it only half turns on so double check with your supplier that you are actually live to recieve messages
Oct 30, 2007 | Motorola Mobility RAZR V3
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
Palm Treo 680 Smartphone Logo
70 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
