Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Engine starts runs for 10 seconds then cuts off
My Craftsman mower has a 21 briggs intek ohv. loks like no fuel to carb. it will run then quickly turn off. it will only start with the choke out
  • 10865 Answers
SOURCE: 21 hp B&S twin-v ohv , engine loading up when blades are engaged
Sounds like the blades are dull. HAve them sharpened
Posted on Apr 21, 2009
  • 225 Answers
SOURCE: Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Posted on Jun 21, 2009
  • 32 Answers
SOURCE: 22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Posted on Jul 20, 2009
ftw1952
  • 10319 Answers
SOURCE: Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Posted on Jun 14, 2010
Testimonial: "Put me on the right track. Machine runs great!"
  • 623 Answers
SOURCE: what type of oil do i use in my briggs stratton
You should be safe with a 10w-30 weight any major brand oil.
Posted on Jun 21, 2010
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Engine is misfiring.
Put the old plugs back in. The new plugs my not be gapped correctly or one may be bad.
May 05, 2014 | Briggs AND Stratton Intek Briggs &...
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Intek engine runs poorly under load and when warm
if you have a ohv ajust valves and you might have to rebuild carb.
Jul 18, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
347 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
