Question about Acer Aspire One A150-1006 Notebook
How do I reformat my computer, because it will not boot up for me to be able to erase the data on it?
  • 101 Answers
First you need to setup your bios so your PC starts with CD first then HD then put in your Windows XP or Vista CD ... when you pc ask "Boot From CD press any key"
then wen CD finished loading choose setup windows then next you can delete partition then Create partition Install windows on selected partition and format drive ... just follow prompts windows will do it easy!
your user manual should have Bios setup instructions :)
Posted on Sep 29, 2009
  • Acer Master
  • 4,806 Answers
If you bought the netbook brand new then in the box you should have a Windows XP Home install disk.
Now because you have not got an optical drive (CD/DVD) in the computer you will need to get yourself an external CD/DVD drive and connect it up to the computer. Pop the disk in the drive and restart your computer. Hit F12 as the computer starts up and select the external drive as the first boot drive. Then you can proceed to re-format and reinstall the operating system.
If your computer has Linux as the operating system you should have a Ubuntu install disk in the box. If you don't you can download the disk free, you are just going to have to use another computer to download Ubuntu and burn it to a disk. Just follow the instruction to boot from the external CD/DVD drive to install it.
Get Ubuntu here >>>>>>
http://www.ubuntu.com/GetUbuntu/download
Regards.
How to completely erase the hd
A hard drive is the brain of a computer. However, over time, that brain can become overworked and overly saturated with old software and outdated information. It becomes clogged and needs a fresh start. By erasing a hard drive, you can give your PC that fresh new beginning. With a few steps you can erase your hard drive manually, without the aid of expensive software.
Make sure your data is protected before you proceed. Whatever you do not save will be lost once you erase the drive. Use a CD or jumpdrive to save your information. Boot with a system disk. Before you continue to erase the hard drive, use the system to create a system disk. Use a 3-1/2 inch floppy disk and format it with the command "format a: /s"; this will create a bootable disk that contains system commands. Place it in the drive of your system and turn it off, then back on. Reformat the hard drive. Once you've booted with the system disk, type "format c: /s"; this will reformat the hard disk, virtually destroying the old hard drive you used to know. Depending on the of the drive, the formatting may take a fairly long time. Once the formatting is over, use the command "fdisk" to create partitions (which are logical sections for your hard drive's storage). Given the newer hard drives and operating systems of today, you can fdisk the drive and use all of the space. or if you dont have a floppy drive Download a disk wiping utility, such as Darik's Boot and Nuke (DBAN) or KillDisk. DBAN is an open-source product, while KillDisk is available as a free, closed-source download. http://www.dban.org/ http://www.killdisk.com/ Once you download the file, save it to your computer somewhere easy to remember. Insert a blank CD into your computer and use a CD writing program to burn the hard disk wipe utility to the blank CD. If you are using Windows Vista or 7, there is a built-in utility that will perform this task. Back up the data on your computer that you want to save, if necessary. Insert the CD that you created into the computer that is attached to the hard drive you wish to erase. Power on the computer and choose the setup option to boot from the CD. Once you have booted from the CD, you will enter into the hard disk wipe utility. Depending on which utility you chose to use, this screen will vary, but the choice you want to select is to erase or wipe a disk drive. Choose the hard disk that you wish to wipe and confirm that you wish to permanently erase the data on it. Before confirming this, you may wish to physically double check and ensure that you are erasing the correct drive. Once you start the erasing process, it cannot be halted, paused or reversed. You will have to wait for anywhere from a few hours to even a few days for the process to complete, depending on how large your hard drive is.
or you could just reinstall another operating system this will automatically delete the old wrong one you installed.
Hope this helps.
Jan 02, 2013 | Western Digital WD Scorpio Blue WD5000BEVT...
How do you erase hard drive
Hope this helps.
Dec 20, 2012 | Computers & Internet
I need to know how to unintall all the data on my WD hard drive and start over again fresh. Can you help me?
Mac OS X
1 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
2 Open "Disk Utility," located in the Utilities sub-folder of the Applications folder.??
3 Select the drive you wish to reformat. Typically, drives appear twice; choose the furthest left.??
4 Click "Erase," and pull down the Format menu. Choose "FAT32." Enter a hard drive name, if desired.??
5 Click "Erase." A confirmation screen will appear, stating that all information on the drive will be lost if erased. Click "Erase." Once completed, the erased drive will function on both Windows and Macintosh systems.??
Windows
1 Download and install the Western Digital FAT32 Formatting Utility.??
2 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
3 Open the FAT32 Formatting Utility and select the desired external hard drive. Ensure that "Restore factory original FAT32 partition" is selected.??
4 Click "Start." A warning message will appear, stating that all data on the drive will be destroyed. Click "OK" to continue. Click "Yes"' to navigate through.?
May 03, 2011 | Computers & Internet
8gb flash drive holds less than 2gb
Try reformatting the flash drive. Copy all your important files somewhere, since reformatting the device would erase all saved data. Go to "My Computer", right click on the usb device, click "Format...", click "Start" on the window that pops-up, click "ok" and wait for the formatting to finish. This should erase all data on the device, including hidden files that might be taking the space up.
Apr 28, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
My computer was reformatted. i can't play any audio/ video materials in my computer.
That is part of reformatting. It erases all of the data that was on your hard drive. you will need to install a new operating system and reacquire your materials.
Mar 04, 2011 | Computers & Internet
Reprogram and reformat
the difference between reprogramming and reformatting is that reformatting just erases and restructures the data stored in the mass storage of the device, where your music is stored. And reprogramming changes the actual operating system and software of a device. A standard using will generally only be able to reformat a player, which can usually be done through your personal computer.
Feb 28, 2011 | Motorola Audio Players & Recorders
How can I remove virus from my Digital Camera coz it cant copy fotos to my PC? please do favor
Reformat the card.
Presumably you have a card reader, and presumably that card, when inserted, appears as another drive on your computer.
"Reformat it. Remove any data you want to keep first, but then reformat it."
That will erase everything from the card. Data. Viruses. Spyware. Everything.
If for some reason you cannot reformat it on your computer, then once again, copy off the data you want to keep, and use your camera or other device to reformat it; most have this as an option.
good luck
and so rate the solution if got help
Nov 29, 2010 | Sony Cybershot DSC-H3 Digital Camera
My imation 8gb pendrive doesnt show memory
Do you mean that it doesn't show any data (memory) stored on it, or that it doesn't even show up as being available storage at all. If it doesn't show up at all then it most likely needs be formatted or reformatted. I would check it in another computer before doing this though, because formatting it will erase all the data that is on it. If its just not showing any data that you saved on it, or that you thought that you had saved on it, then maybe you weren't going thru the proper steps to save info\data on it, or it got reformatted without you being aware of it. It is possible for any type of flash drive to be erased and\or damaged by being improperly removed from a computers USB.
Aug 04, 2010 | Computers & Internet
Reformatting my gateway laptop to factory settings
Depending on the model you can use disks it came with or hit F10 or F11 key as it boots. Should then bring you to recovery menu. Then just follow the menus.
Keep in mind it will erase ALL of your data.
Hope this helps.
Apr 05, 2008 | Computers & Internet
Boot error please reformat
Reformat the player.
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Mar 17, 2008 | RCA OPAL M4001 MP3 Player
Acer Aspire One A150-1006 Notebook Logo
131 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
