Question about Ruud UBHC Air Conditioner
RRUDD ACHIEVER 30, OUTSIDE FAN WON'T SPIN.
THE UNIT RUN IN SIDE THE HOUSE. IT BLOW AIR OUT IN THE HOUSE.BUT THE FAN OUTSIDE WIL NOT SPINE AT ALL.I WAS TOLD IT THE MOTOR. IF SO WAST THE COST FOR THIS .
  • 22 Answers
Does the unit outside run at all,can you hear a humming noise or the compressor run or is it just dead.if you hear the comp. run or a humming noise then i would say it needs a new motor.but if you hear absolutely nothing out there,what i would do if you dont have a meter, is open panel on condenser and push the contacts in on the contactor when this is done its like jumpstarting the unit,it should all come on ,compressor and fan motor,if motor comes on then your contactor is bad (cost approx.$50.00) if it doesnot come on then its motor when replacing motor be sure to get a new capacitor with it (cost $80.00 to $120.00 plus cap 5mhz.$5.00 to $15.00) depends on where you get it home depo/menards/etc.high priced try granger or a local a/c distributor youll get it much cheaper.hope this helps
Posted on Sep 29, 2009
Air conditioning condensor on side of house not working
sounds like you need to check your run cap it is silver in the outside unit and it runs the compressor and fan motor. Check on the capacitor what size it is and replace it for example 45+5 uf.
Sep 07, 2014 | Carrier Heating & Cooling
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
I have a 15-year old Ruud Achiever 10 A/C unit outside that has blown a second set of fuses in just a month. The fuses are in the box on the wall adjacent to the unit. What may be causing the fuses to...
A BAD RUN CAPACITOR INSIDE THE CONDENSING UNIT ?.SEARCH YOUR AREA FOR FREE CAPACITOR TESTING.OR LOCAL ELECTRIC MOTOR REPAIR.. CHECK THAT FAN SPINS FREE, IF NOT, IT CAN BE OILED .. SEARCH POST ON OILING FAN MOTORS
Jul 26, 2011 | Ruud Matching Split Air Conditioner
First time using my air conditioner after winter. my "inside" fan will run but the outside unit is not starting. My weather king is approx 9 years old
Check fuses and circuit breakers to the outdoor unit. Fuses should be right next to the unit in a box on the side of the house. Easiest thing to do is replace them both. Circuit breakers are in you circuit breaker box. There will be two of them, probably 30 or 40 amp maybe 50 amp if a big house. Trip breakers all the way back and then all the way forward. Hope this works.
May 11, 2011 | Heating & Cooling
My air conditioner fan is not working
Check the outside fan and make sure it rotates freely. If it doesn't spin freely it needs to be replaced. If it does spin freely then check the capacitor. If the capactitor is OK the check the fan motor windings for continuity with an ohmmeter. Let me know what you find.
Jul 18, 2010 | Heating & Cooling
Air conditioner fan runs outside but won 't blow cold air in house. It's 78 in there. The unit is only 3 years old.
is any air coming out? check the fan. then the evaporator coils in the furnace plenum. see if the condensation drain is plugged. see if the coils are iced up. is the thin tubing very warm? if not, you may be low on refrigerant.
Jul 29, 2009 | Heating & Cooling
Ruud Achiever 10, outside Fan wont spin unless I help it.
The part you are talking about is called a capacitor. They come in various voltages and ratings. The best thing to do would be to find the rating tag on the motor, and look for the capacitor rating. There are many, many different sizes and types, so it is best to consult a proffesional before attempting to replace it on your own.
Jul 06, 2009 | Ruud UBHC Air Conditioner
Replace Rudd Achiever 10 ???
if the fan motor outside let go it could overheat the compressor which he should have known before he replaced the motor. also there is no way of knowing if there is enough freon in the system if the compressor does not start,your best bet is to get another repairman as a second opinion
May 12, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Airconditioner problem
This unit has a bad Start/Run Capacitor or a bad Fan Motor! Replace the $10 Cap...An then the $90 fan motor if the Cap dont solve it!
Oct 01, 2007 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
228 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
