Question about Maytag MDE2706 Electric Dryer
WAS RUNNING FINE AND MOVED IT TO DIFFERENT HOUSE AND WOULD NOT RUN
    President:
  • 1,776 Answers
Unplug the machine and check for a blown thermal fuse. It's located just inside the rear of the dryer and is usually attached to or near the exhaust duct. It's about one inch long and can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 29, 2009
Dewalt miter saw not running at full speed
Problem will be either low brush lengths or burnt armature. Check for arcing when running and excessive sparking will mean motor over haul or replacement.
Jan 21, 2013 | Dewalt Mitre Saw Workstation
I moved my TV from my old house to my new house. Before it worked just fine at my old house, brought it to my new house and it just doesn't turn on! Tried different outlets, wires, etc.
Check the power at the plug point. Check the plug of the TV. If there is no life, then you will need to open the TV panel and check for a blown fuse, a circuit break while transporting, a loose connector within the set or a possible damaged SMPS>
check this link below for some tips on the power supply:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 21, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My printer was working fine until I moved. Once I
check the rating is correct. if the plug has a fuse check that. try a different wall socket
May 09, 2010 | Office Equipment & Supplies
I have a Whirlpool refrigerator, Model # ET18NKXFW0 1, Serial # EG5130791. It has working fine for 12 yrs. I recently moved it from one location to another in the back of a pickup on its side. As soon as...
Refrigerators should never be plugged into a GFI due to the start up amps that it draws on start up. With other items on the same circuit it is too much of a load. Refrigerator need to be on there own individual circuit to keep this from happening and not a GFI. Hope this helped.
Feb 02, 2010 | Refrigerators
Washer tub won't stop filling with cold unless tap is off
Sounds like jammed open solonoid valve on hot or cold......water?,,quite simple to fix parts about *£8.00
Nov 02, 2009 | Washing Machines
Knocks out house curcuit breaker and stopes running. Use to work fine and did for at least two years now kicks out breaker after running for a while. Have moved it to different circuits and still does it....
You will need to put an amp meter on the compressor wires and monitor the reading till it trips the breaker. If the reading exceeds the name plate spec then chances are the compressor is going bad.If the spec is in watts, take your amp reading and multiply it by 120 volts this will give you the wattage of the compressor. For a second opinion take it to repairshop to see if it is worth repairing.
Good Luck!
Aug 15, 2009 | Maytag M7DH65B2A Dehumidifier
Wmn20a ODORS
How long has the unit been running for? sometimes with these newer heating elements it takes a while to burn off the oils used to make them.
May 29, 2017 | Desa International CBP20T Wall Mounted...
Leaking water
If it was moved with a dolley the dolley may have broken the water pump under the washer.
Mar 14, 2009 | Maytag Atlantis MAV8000
Drive Being Recognized as Removable Disk
Use EASEUS Data Recovery Wizard to recover the data. You can find the program on the internet..
To format afterwards click Start, click Run and type compmgmt.msc.. In there format your drive..
Mar 10, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Maytag MDE2706 Electric Dryer Logo
53 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
