Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Whirlpool Cabrio top load washer won't start now but it first started by giving LD code when would wash only heavy items like full load of towels or bedding (all others ok). If I let it sit for awhile it would work if turned to rinse/drain cycle. It was same on any cycle but not with other items. Now when I try to start the machine itself for anything I can turn it on (it will power on), set everything but get nothing (not even code) when hit start. Sometimes the lid will lock sometimes it won't when I hit start. I've tried all settings, temps, etc just to try to get it to start to no avail. I've checked the drain hose and it is clear.
We ran into this problem with ours too. I swear, this washing machine is the biggest piece of junk I've ever bought.
We used to get the LD code at the beginning of each load of wash. We solved this by manually holding the lid down tight until the lock mechanism clicked in place. Once locked, it should stay that way for the duration of the wash cycle.
One day, it just stopped giving us locking problems.
Posted on Oct 02, 2009
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Machine gets off balance when washing heavy fabric items, such as towels and blankets
only wash 1 to 2 blankets max and set water to high when you put them in start with a corner and go around the center plunger and feed them in as equal as you can it should help if not at least not as bad the machine may need to be leveled as well this is very very important for a washer mope this helps
Aug 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer gives LD code& just tries to drain with no spin
LD code means the long drain.You may have something clogged in the pump or the pump would be bad.Tilt he washer back from front,remove panel underneath.This will give you access to the pump.
Apr 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Yes, my cabrio washer will not drain and it had the code Ld showing, any help??
did anyone give you an answer to this problem, i am having the same thing happen to me
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Jan 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
597 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
