Question about Alpine Air XL-15 Air Purifier
Living Air XL (no smell)
My machine produces no smell. The fuse is good and the fan works--although I did notice that the two little lights near the glass plate doesn' come on. Can you help me?
jimbosr
  • sixflights Mar 28, 2008
    my machine goes on and runs, however it does not smell...it is not dirty and all the lights seem to be on in the unit....what else? I changed the glass plates out, no effect.
  • mbaker5 Dec 02, 2008
    Runs, but has no smell. I can see one little orange light on, although dim.
    Problem Solver:
  • 16 Answers
Pull out the plates and clean contacts that touch plates with rubber eraser then put plates back in check switch on back of screen to make sure its making contact.
~~~creekkid~~~
Posted on Mar 29, 2008
2 Suggested Answers
namizhka
  • 148 Answers
SOURCE: Living Air XL (no smell)
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Posted on Sep 25, 2008
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
Sep 25, 2008 | Alpine Air XL-15 Air Purifier
Hi-I have the Living Air XL. It's out for repair because I cannot smell the distinct clean smell it normally puts out. The repair guy just called and said it's fixed and running, but the green light bulb...
He probably cleaned the unit and restored the plaques. Green light or no green light, it doesn't affect the production of ozone. If still in doubt, when you go to pick it up, have him operate fit or you before you leave the store. I've had one 7years and the green light hasn't worked for three years. I clean it regularly and it still produces ozone when needed. Regular, routine maintenance is the answer.
Mar 28, 2011 | Ecoquest Living Air Classic Air Purifier
My living air xl-15 prove it light does not come on anymore and it seems that the unit does not prodoce ozone. I tested the light in the normal postion set at 12:00 with the plate out but to no avail....
If you are sure that the plate is clean, in perfect condition, and inserted correctly, it would appear that the transformer is defective. This means that power is not going through the metal contact fingers into the plates.
The light probably has burned out. It is not essential to the working of the machine, so it isn't anything you need to be concerned about.
Vollara (formerly Alpine/EcoQuest) is no longer producing or servicing the XL-15. However, a newer version, called the Classic, is available. You can call Customer Service 800-989-2299 and they will tell you your options. Use #16618 if you need a referral number.
Jan 08, 2011 | Alpine Air XL-15 Air Purifier
Have a Living Air XL15 > everything works motor, fan, BUT .....
look through the front grill while its "on" you should see a glow from a neon lamp inside. If its not on chances are the circuit card is dead (should have about 350VDC plate voltage).
I have a used but good board if anyone needs one.
dale.gilchrist@gmail.com
Apr 26, 2009 | Ecoquest Living Air Classic Air Purifier
No Ozone
Mine has a switch lower right hand side that will stop the ozone.
Aug 31, 2008 | Ecoquest Living Air Classic Air Purifier
Air Purification Unit Model ALP-615
Moist air reduces the efficiency of ozone production for this unit. I am not sure what the water thing is about.
Did you try cleaning the glass plate or ceramic plate ozone producing unit with soap free ammonia? Also did you try using a pencil eraser on the contact points on the glass plate? I think the ammonia cleaning and contact points on the glass plate should be your first option. Check your maintenance on the units manual.
Try the manufacturers website for their trouble shooting guide...walks you through most problems and how to fix them.
Apr 22, 2008 | Alpine Air XL-15 Air Purifier
Alpine Air Living Air XL15 not producing Ozone or Deodorizing. New plates
Confirm that the appropriate sections of the circuitry are powered up and drawing power; check the interlock switch action; toss it back to the maker because the Hi-V transformer or ladder circuit or sense or hold caps were (if testing proves) never quite functional.
Dec 03, 2007 | Alpine Air XL-15 Air Purifier
Fan is not turning on
The fan motor is probably locked up. You can either put a little oil to free it up (usually a temporary fix) or better yet replace the fan motor.
Oct 26, 2007 | Ecoquest Living Air Classic Air Purifier
Alpine Air XL-15 Air Purifier Logo
904 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
