Panasonic DP-8045 Grayscale Copier Logo
Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can only receive faxes not send faxes, when sending the fax goes into memory and is never sent???
Anonymous
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Oct 15, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
37528
Points
107
Have you gone into fax param. and made sure sending is not turned off or set to manual?
Cant send fax out. getting a message exceeded job memory. How do I clear this
Dear
As the model is not mentioned its difficult to right solution. But in general when a document sent from memory some times this happen. This is frequent if memory recieved is more and not printed.
Its cleared on printing all memory recieved or memory cleared(all received fax will deleted).
Also sending fax manually may be done.I.e.Dial the fax no.get the fax tone load the document press start or send. Also in setting the scanning resolution may be minimised up to150/200dpi for less memory.
Thanks.
4helpful
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
4helpful
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Says memory is low cant print how to fix
Do the following:
1. Make sure that the memory does not have any faxes in it waiting to be sent if so send them.
2. Make sure that the memory does not contain any received faxes still waiting to be printed if so print them.
3. Use the HP ToolboxFX Fax tab to perform fax tasks from the computer. The Fax tab contains links to the following main pages:
● Fax Tasks. Perform such tasks as sending a fax or clearing the fax memory.
Fax Data Properties. Manage the space used to store faxes on a computer. These settings apply only if you have chosen to send or receive faxes remotely from the computer.
Enhanced I/O
The enhanced I/O (EIO) feature allows all-in-one memory to be used for storing data received from the
host computer. When EIO is enabled, more data can be sent to the all-in-one in shorter amounts of time
so that the user can return to the software program more quickly. The
EIO feature has the followingoptions:
Auto. The all-in-one uses EIO memory allocation to increase the speed of data transfer from the host computer to the all-in-one, if necessary. The default setting is Auto.
Off. The minimum amount of all-in-one memory is used to store data that is sent from the host computer.
Page Protect. The formatter creates the entire page image in page-buffer memory before physically moving the media through the all-in-one. This process ensures that the entire page is printed.
3helpful
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
1helpful
Fax not sending or receiving
hear fax can send but fax is recevieing so what is the solution
2answers
Send and receive
Most likely has a problem with the fax PCB board inside it. Its not worth repair.
1helpful
2answers
Memory tx
It means you have a fax in memory that cannot be sent.
Do you have DSL or any kind of digital phone line? Do you have a dial-tone?
Unplug the power cord and re-plug.
Fax will not send
Does the receiving or sending party have a DSL phone line?
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
