Question about GPS
After activation, Garmin nuvi 205 turns on momentarily, then turns off. Happens whether plugged into car power of if battery used.
    Top Expert:
  • GPS Master
  • 77,201 Answers
This can be caused by a defective battery or a software issue, there is nothing on this GPS that is owner repairable, you can't even take it apart without the special tool to split the case halves, Garmin has an exchange program, you sen the unit in and they send out a refurbished unit, very short turn around time. Before you u send it in try resetting the unit, there is a button inside a ting hole to do this, it is clearly marked, if that doesn't work u will need to send it in for exchange. here is the web address for Garmin support.
https://my.garmin.com/mygarmin/marketing/register.htm
Posted on Sep 29, 2009
Garmin 205 how to charge on computer?
follow the steps below:
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disappear.
Good luck.
May 27, 2010 | Garmin nuvi 205W GPS Receiver
Well not turn on
This is likely a failed battery.
The battery on these units is not user-replaceable (soldered to the PCB) and must be returned to Garmin for repair.
CLICK HERE to see more about their FLAT RATE repair service.
Your nuvi 205 is listed as a $69 flat rate repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 17, 2010 | Garmin nuvi 205 GPS Receiver
My garmin nuvi 205 will not power on. I have plugged it in to charge the unit and it updates maps and shows the charging screen. Afterwards I unplug the unit and slide the switch over and it will not power...
Your nuvi 205 is listed as a $79 flat rate repair.
Apr 16, 2010 | Garmin nuvi 205 GPS Receiver
Garmin won't charge or turn on.
Hello :
How old is your battery ? I think that the battery life is ended [ can't be recharged anymore ] . Just replace it and problem will be solved .
please rate !
Apr 14, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi® 205 Car GPS Receiver Try to recalibrate and it is frozen
If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
Then I suggest a hard reset.
Finally, replace the firmware and system software using webupdate.
Replacing the firmware should allow it to power up successfully after the update.
I hope that helps.
Mar 28, 2010 | Garmin nuvi 205W GPS Receiver
Yesterday my Nuvi 205 worked fine, today it will not turn on. I have verified with another unit that the charge cable is fine and the other units charger will not activate my Nuvi
Then I suggest attempting a hard reset.
Finally, replace the firmware and system software using webupdate. Your Nuvi should not need to be able to power up for a firmware update to be possible - replacing the firmware should allow it to power up successfully after the update.
I hope that helps.
Mar 27, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205 gps trouble shooting will not power on
If your Garmin NUVI 205 can be recognized by your computer when it is plugged in, I recommend you backup your favorites. Then I suggest a hard reset.
I hope that helps.
Mar 23, 2010 | Garmin nuvi 205 GPS Receiver
Nuvi 205 dead
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
Nov 17, 2008 | Garmin Nuvi 660 GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
GPS Logo
12 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
