Question about Yard Machines Red Edger
Seeking YardMan Landscape Edger Blades
I am looking for edger blades for my Yardman gas edger- the type for edging borders around flower beds and trees. Where can I get them? Can you point me in the right direction?
  • bstudzi
    bstudzi May 31, 2012
    I was able to order mine through Sears. Its Craftsman 9x2 1/2 inch with 5/8" center hole part # 71-64953, Its for Craftsman edgers using Part numbers 781-0080.
  • 148 Answers
Locate the model number of your machine and click here.
In the center of the page, click on "Launch Illustrated Parts Look-Up Tool".
Enter your model number and click "Search" to find your part number. You can order the part direct using "Quick Order" on that site.
Hope this helps.
Posted on Sep 30, 2009
Yardman troubleshooting
I suggest that you should remove deck, turn upside down and place straight edge or tight string line over blades from outer edges of deck frame. Use the guide strips to get even measurement. Rotate blades and measure distance from straight edge to tips at both sides. they should be the same. If there is difference from one side to the other, either the blades are bent, or if each blade is same at each end but not aligned in centre (difference in height) then the spindles need packing to make them even. Check that bearings are not loose. If you do not understand this best to take it to service centre.
Jul 23, 2014 | Yardman Yard-Man 13AC76LF055 38-Inch 344cc...
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
I am looking for part # 731-1939 Belt Guard for a model 25A-564A401 Yardman Edger. Can you assist? Thanks. Bob
Bob by my system this part is nla. i work at a lawn mower shop and we sell mtd parts
Sep 21, 2011 | Yard Machines Garden
I bought a homelite curb runner and need to replace the blade. The problem is I cannot find the blades anywhere. Any ideas?
I found that your electric edger blade is rounded on the ends. I did not find a part number for it. I also found a site that has about 30 or more Homelite edger blades listed, but again, with half of them without pictures, I can't give you the edger blade part number. But, if you have removed the blade and can measure all the dimensions of the blade, then you can match it up with one from this site.They have more blades than other sites I checked. It should not be too hard as each blade listed has the critical dimensions listed with it. I wish you good luck.
http://www.mowtownusa.com/42.html?m5:search[keyword]=Edger%20Blade;search[keywordSearchType]=and;search[matchWholeWords]=1;search[keywordFields]=string0:text2:text0:code;search[active]=yes;search[fuzzy_sku]=1
Jun 19, 2011 | Garden
How to install a yardman edger belt
i changed the belt on mine today. The belt will loop over the back left pulley then inside the middle pulley with the back of the belt towards the bottom pulley and the v shape in the top of the pulley you then pull the belt over the front pulley( next to the blade) with a screwdriver and thats it.
Aug 25, 2010 | Yard Machines Red Edger
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
Mower blades belt keeps breaking
Did you get a manufacturers belt? sometimes belts that look the same don't work. My belts kept breaking because the pulleys were dirty with grit, dirt, and grass. Hope this helps.
Oct 04, 2017 | Mtd Products Yard Machines 158CC Tiller
Can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Aug 03, 2009 | Garden
Are you supposed to sharpern the blades on the edger occasionally
Hello:
No. Edger Blades are Not Sharpened.
Respectfully
John
May 09, 2009 | Black & Decker Le750 Lawn Edger
Yard Machines Red Edger Logo
141 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
