Question about Ryobi Garden
Have just gone to use the said strimmer and i find i can't find the operating instructions, or the mix required. the strimmer is a ryobi 2543 petrol strimmer
SOURCE: Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Posted on Mar 17, 2009
  • 8 Answers
SOURCE: What is the correct fuel mixture for this machine
Every Stihl I have ever touched requires 40:1 fuel mixture.
Posted on Jun 02, 2009
pippall
  • 1486 Answers
SOURCE: petrol oil ratio mix
25%to!%
Posted on Aug 09, 2009
57 varieties
  • 1653 Answers
SOURCE: My Ryobi PLT 2543 strimmer will run, but cuts out
I had this problem twice in the past. I solved it the first time by replacingthe plug and setting the plug gap with a feeler guage. The next time it was a decoke of the cylinder (squirting through the plug hole) replacing the plug and leaving it overnight and then cleaning the air filter. It runs like a dream and has worked in Australia, Europe and the UK with no further problems. Also the fule mix has to be just right, I actually use 22:1 instead of 25:1 and do not use any petrol / gas with additives in (like Shell).
Posted on Aug 29, 2009
SOURCE: Manual - Ryobi RLT30CES strimmer
Try this one:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Cheers
Nigel
Posted on Sep 10, 2009
Testimonial: "Thanks. Got it."
Where can i get a piston ring for ryobi strimmer,its a 25cc,model number PLT 2543.
Some of these small engines have very limited parts availability so that part may not be available. Try www.jackssmallengine.com
Oct 27, 2016 | Ryobi Garden
Hi what is the ratio of oil to petrol on the 26cc petrol strimmer
Usually on a 2 cycle engine I will use 32-1 mix. Most engines will be fine if you get a name brand oil like Ryobi, Still, Echo, etc, with a pre-measure area made on top of the bottle. Follow instructions (usually 2.6 ounces per gallon.)
Feb 25, 2015 | Garden
Strimmer instructions what mix do I use for a bluebird strimmer
Hi Chris the usual mix for any trimmer is 40 parts petrol to 1 part two stroke oil. Each tank of fuel I do usually gets a dribble to make it look slightly pinkish. Not to dark though or it smokes terribly.
Apr 22, 2014 | Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
I've lost the user manual for my Ryobi 25cc RPT 2543c strimmer. Can you please advise where the dip stick is to check the oil. Can't seem to find it.
Ryobi RPT 2543c This is a 2 stroke engine, so no dipstick. You mix oil with the petrol (ratio 50:1) or 200ml of two stroke oil per litre of petrol, and that's how the engine is lubricated. Hope this helps, arvidis@btopenworld.com
Apr 19, 2011 | Ryobi Garden
My Ryobi PLT 2543 strimmer will run, but cuts out when the throttle is opened
Aug 29, 2009 | Ryobi Garden
Ryobi PSC 3046y3e 30 cc petrol strimmer ratios of petrol to oil
WELL IF THERE IS NO 2 STROKE OIL TANK THEN YOU MIX IT WITH THE GAS. THIS IS HOW THE ENGINE GETRS ITS LUBRICATION AND WILL BLOW UP AND SEIAZE WITHOUT IT.MOST OF THESE SMALL ENGINS RUN AR 20 TO 1. OUTBAURDS RUN AT 50 TO 1. IF YOU PUT TO LITTLE ITS NO GOOD AS MENTIONED ABOVE. IF YOU [PUT TOO MUCH IT IS NT AS BAD AS IT WILL SMOKE A BIT AND POSSIBLE FOUL THE PLUG AFTER A WHILE. I WOULD GO WITH 230 TO ONE THAT WOULD BE 20 PARTS GAS TO 1 PART OIL 20GAL GAS TO 1 GAL OIL IS THE SAME AS 5 GAL OF GAS TO 1 QUART OIL OR 2 1/2 GAL GAS TO A PINT OIL OR 1 1/4 GAL GAS TO 1/2 PINT OILM GET THE PICTURE NOW. ITS DIVISION. AFTER A WHILE OF RUNNING IF IT SMKES AND THE PLUG FOULS JUST ADD A BIT MORE GAS TO YOUR MIX AND CLEAN THE PLUS WITH AN OLD TOOTH BRUSH AND I ALWAYS MARK MY GAS CAN WITH BLACK MARKER OIL/GAS MIX 20:1 OR WHATEVER.
REGARDS, PAUL
Jun 20, 2009 | Ryobi Cultivator
Ryobi RLT30CES
I have one of these and I have to admit they are a bit of a bug*er to start. Following the instructions though on the sheet for trying to start it eventually should kick it off and then you should be away. I start mine by alternating between no choke and the half choke with about half a dozen pulls each. generally pull with the throttle held but try a few with it off every now and again. If you get to 10 mins without success, put it down, have a drink and a rest and go back in 30 mins and try again.
I wouldnt have thought a straight petrol mix would do it any harm though, if you had over mixed with oil then that could have been a differnt story.
May 25, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
205 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
