Hi. When i turn my drive on either with the IDE cable plugged into the drive or not it starts spinning the drive like normal, and then it starts going through a series of clicking. It's the arm for the heads moving around in the HDD. I pulled the case off of the drive and looked. there's no noticable problems with the internals of the device. I'm curious if anyone knows of any common problems for this to be occuring, and if there's any way to fix this issue.
Any help would be greatly appreciated.
Thanks
Bryan
I get this same clicking noise and then the computer shuts down and I get a blue screen. I have to unplug the computer in order to turn it off.I get this same clicking noise and then the computer shuts down and I get a blue screen. I have to unplug the computer in order to turn it off.
You can't post conmments that contain an email address.
Your description has me confused. I'm not clear on which power and data cables you are using. You described pulling one cable from first hard drive and connecting it to your second drive. Extra power connections should have been in a loose wire bundle somewhere in the computer. (Often they are tucked into an unused drive bay.)
The SR1720NX has 2 SATA controllers and two IDE controllers. Thus it can have 2 SATA and 4 IDE devices. The computer sometimes shipped with a SATA hard drive or an IDE hard drive. In all cases, the hard drives must be connected to the data cable (and to the motherboard) and then the power connection from the power supply has to be connected. So there should be 2 cables plugged into each drive. The optical drive is usually an IDE drive for this model, also a master drive.
The IDE power connection is a large 4-pin Molex connector; the SATA power cables are a smaller 5 pin connector. There is also a small 4 pin connector that powers a floppy drive, if present. IDE data cables are a wide 40-pin ribbon cable (sometimes an 80-pin cable for master/slave). The SATA data cable is a 15 pin cable.
First make sure that the jumper on the drive from the A430n is across the two pins in the second position (counting from the side away from the power connection). This is the cable select option. Next make sure that the IDE cable is firmly connected to both drives and the motherboard. (I've sometimes loosened the data cable while connecting the drives.) Finally check that the appropriate power cables are firmly connected to all the drives. Then power up the computer. (With the second drive on the Slave connection, if the device on the Master connection isn't powered up/recognized, then weird things may occur.)
BTW: you should be alert to the power needs for the computer. The original power supply could be overloaded with the extra drive. You might be better off using an external drive enclosure (USB) or a USB/SATA/IDE dongle that leaves the drive out in the open. Connect these with extreme care following the directions for when to connect the power supply. Some enclosures won't work without reformatting the drive - you do not want one of those.
If
the computer cannot boot up then to retrieve your data then remove the hard drive
from the computer and connect it to an USB hard drive adapter. Then plug the
adapter into a working computer's USB port. This computer will detect this as an
external storage device. You can then click on this device and open the folders
and files to copy and backup your data files.
Hi, It sounds like the internal hard drive has failed especially if this happens when you try and record a program, this will be the clicking sound that you can hear. If the unit is fine until you try and record the i am in no doubt that it is the hard drive and it needs to be replaced. Most new recorders have three and half inch IDE/ATA hard drives in them but it is a good idea to check first before you commit to purchasing a new one.
That clicking sounds if ever loud enough is one annoying symptoms of failed disc. When it accidentally drop the reader may come off the disc. It sad to say but you may consider to change your hard disc.
I'm assuming this is an internal drive since you are mentioning it not appearing in the bios. If the hard drive is not recognized by the bios check to make sure that the power and IDE or SATA drives are plugged in all the way. If there power, you will hear the unit spin up when you start the machine. If you do not hear the drive spin when the machine starts, make sure the power (for pin) plug is plugged in all the way and attached to the power supply.
If the drive does spin up, then verify the IDE cable (flat ribbon cable with long rectangular connectors at both ends) is plugged in all the way and that it is oriented in the correct direction. There is normally a key at the top (square pin) so that the cable only goes one way. If there is no "key," look at the drive. One end should be labled with pin "1". One side of your cable should have a line that is different than the rest of the cable (normally red). This corresponds to pin "1."
Make sure that the IDE cable is completely plugged in at both the drive and the mother board.
If this is a SATA drive, then you should verify that the SATA cable is attached firmly to the hard drive and the mother board. My guess is that your drive is an IDE drive.
The high pitched whine in reverse sounds normal for a honda. Ever honda I have had makes a similar noise while in reverse. The spinning, scraping noise in drive is not normal. You might want to see a mechanic about that.
Laptops have very few moving parts. Your problem is more than likely either a fan or your hard drive. Remove the hard drive, start the computer up and just let it run for awhile. If the clicking noise never comes up then thats your problem. If it does, its probably a fan.
Disregard anything on the screen itself, just let the PC run. It sounds like after the hard drive has been spinning for a minute a motor starts to die.
This is a common problem with hard drives. Most hard drives (whether external or internal) that
produces a "weird clicking noises" indicates a mechanical problem.
Often this is the head arm trying to move from its position but failing
to do so. What you are hearing as "weird clicking noises" are when it slaps back to its
park position or when trying to move into correct position.
Should this be the case, am afraid that the HD is
a goner. The normal course of action is to replace. If the data inside
are mission critical, your only course of action is to avail of those
data recovery by firm specializing in such but they are rather
expensive.
Trying to use "data recovery software" might prove to be futile since as earlier stated, the problem is mechanical in nature.
You can of course still give it a try.
Should
you feel adventurous, would be willing to experiment and gamble, pls
post back as I may have not a permanent solution but a "down &
dirty" trick of making it run long enough hopefully to get some of your
data back. Again, this is a "hit or miss" and should only be considered
if all else fails and you really want to get your files back.
Hope this be of some help/idea. Pls post back as requested, how things turned up or should you need additional information.
