Question about Panasonic CT-32SX31 32" TV
Won't turn on
Where are the fuses located on the Pansonic CT-32SX31 32" TV?
  • eguy Feb 14, 2008
    How are you supposed to remove the fuse? Removing the panel for the AC cord yields a hole too small for a hand. I tried to use a pair of forceps. I was able to remove the fuse, but then it popped out of the forceps and into the bottom of the TV, so I don't even know for sure that the fuse was the problem. Do you know how much the TV weighs? I recall it took all three delivery guys to put it in the armoire, and it was still a struggle. It hasn't moved from there in six years.
  • MOUC13 May 11, 2010
    I have a Panasonic colour TV CT-27SX11CE with the same problem; it won't turn on. I tried the solution given here for a CT-32SX31 TV by Terryfic (posted Dec. 19, 2007); I followed the AC cord, I removed the cover plate, I don't see a glass fuse. I can see some components but don't know what they are, fuses maybe?
    Genius:
  • 1,694 Answers
Follow AC cord in to clip-in glass fuse....replace with SLOW
BLOW 6.3 amp ( T-type) Panasonic factory correction...T.
Posted on Dec 19, 2007
  • Vista Electronics Dec 24, 2007
    joydaw,
    Looks like a double entry...if everything is still ok,can we
    clear this entry ? If you any further assistance , let me know..T.
I wasn't able to retrieve the fuse from inside the TV, but Radio Shack had replacement 6.3 amp slow-blow fuses and I was able to get one into the receptacle, being a little more careful with the foreceps this time. That's all it took, and the TV is working again. Thanks Terryfic, for identifying the location & type of fuse.
Posted on Feb 15, 2008
2 Suggested Answers
experttv
  • 203 Answers
SOURCE: Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Posted on Sep 12, 2008
If I connect antenna coax to the tv in on my dish receiver, can I get ota programming on my non-digital signal ready tv with out a stb?
Hi James,
Normally, no. Most areas have gone digital-only. Here in Canada, just about everywhere has completed Phase II of our DNU (Digital Network Upgrade) regulated by the CRTC... meaning that you will need a STB to view any sort of programming.
Check with your local cable provider to see what's up. They'll know for sure.
Hope this helps!
Mar 01, 2015 | DISH Network 311 DTV Receiver
Pansonic CT-32HXC14
This is a bad connection in the power supply, or a bad connection in the high voltage supply, and could also be expensive to repair if the regulator board is intermittent. I say if you can take it back, good riddance. Good Luck
Jul 27, 2007 | Panasonic CT-32HXC14 32" TV
My pansonic tv model ct-13r37s won't turn on by
if their is no any power indicator at the front panel the cause is either the primary fuse at the power supply section blown. and then if the fuse is blown that was mean the regulator transistor and the horizontal out put transistor could also damaged. this case can be hand held by trained technician. if you want a do it with your own just make sure you have at least a basic knowledge in electronic repair since you are dealing with some high voltage parts a care must be needed.
Aug 12, 2012 | Televison & Video
My pansonic ct-13r37s won't turn on and I have no
Buy a universal remote and simply enter the right code which will come with the remote and your ready to go.
Horizontal lines across TV screen Pansonic CT 35g25
Check its vertical output section circuit for any component damage or loose soldering terminals. Check the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying al little more fresh solder, without making any solder bridge short in between adjacent solder terminals.
If this do not help you, replace the vertical output IC. Lose of Vertical Scan is the problem of your TV.
Aug 04, 2012 | Panasonic CT-35G25 TV
Looking for Part Number : KFT6AW45SF
There is no such FBT to Pansonic. Contact the nearest authorised service center for Panaonic at you town for details.
May 11, 2012 | Panasonic CT-32SL14 32" TV
Where is the fuse on a Panasonic CT-32HC43. It just won;t turn on. It was working great and then nothing.
The fuse is located on the power supply board. It looks like a small glass tube with metal caps at both ends like the ones in the image below on the board next to it you will see a small marking that says the specifications of the fuse. Ex: 10A(Read 10 Amperes), 120V. The replacement you are gonna purchase should be of the same specifications. Make sure you unplug the tv from the power supply before replacing it so that you will avoid the risk of electric shock.
A positive rating for the advice provided will be highly appreciated and I will be glad to assist you further if you need more help.
Sai.
Mar 29, 2010 | Panasonic CT-36HL43 36" TV
Where is the fuse located on the panasonic model CT-32SC15N tv?
Usually on the power/deflection circuit board inside TV
Jan 07, 2010 | Panasonic CT-32SL14 32" TV
Won't turn on
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
Panasonic CT-32SX31 32" TV Logo
567 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
