Question about HP 32sII Calculator
Have new batteries but unit will not come on - HP 32sII Calculator
  • HP Master
  • 8,023 Answers
Adjust contrast : Hold down [C] key and press [+] to increase contrast or [-] to decrease it.
Diagnostic tests (from the Users manual)
1. Hold down [C] key and press [LN]; may have to repeat several times.
2. Press and hold down [C] key and press and hold down both the square root key AND the Sigma + key. When all keys are released, MEMORY CLEAR is displayed.
3. Remove batteries and lightly press a coin against both battery contacts in the calculator. Iy should say MEMORY CLEAR.
If these steps fail to restore calculator operation, it requires service.
Hope it helps.
Posted on Sep 29, 2009
How do I reset the main unit of my weather station. I just put new batteries in the sending unit.
  • Remove all batteries
  • Install batteries in sending unit. Allow time for sending unit to begin transmitting temperature
  • Install batteries in main unit. You should see outside temperature displayed
Jan 10, 2017 | Measuring Tools & Sensors
My sensor isn't sending signals to main unit for outside temperature .This unit is brand new and has new batteries
  • Remove all batteries from both units
  • Install batteries in sender. Allow time for sender to initialize and begin sending signal
  • Install batteries in receiver. You should see outside temperature displayed
Dec 29, 2016 | Measuring Tools & Sensors
Changed battery and changed all detectors and they still cherp
Try installing all new batteries. Latest installs have the individual units also hard wired to each other so that when one goes off the others are triggered. When a battery is weak in unit it often causes the main unit to chirp along with some of the others in sympathy. If still no improvement and all batteries are brand new, then either get new units or disconnect the hard wiring between all units.
They will still work but without the nasty global feature.
Dec 22, 2016 | Home
Why isn't outdoor temperature displayed on indoor unit?
I have a La Crosse unit right in front of me and it is showing +18 F tonight. Saturday, we are supposedly going to sub-zero.
With regard to your problem, La Crosse instructions are very specific about the battery replacement procedure. Remove all batteries from both units, then install new batteries in the outdoor unit. Allow time for the outdoor unit to "initialize" and begin sending temperature data. Install new batteries in the indoor unit and you should see the outdoor temperature displayed.
Feb 12, 2016 | La Crosse Technology Wireless Temperature...
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
The unit was not chirping but I decided to replace the battery. After I put in the new battery the unit is now chirping.
Replaced another battery,brand new battery a must,press the test button,by letting it goes off like 30 or 40 sec. so it will detecting the new power of the battery.The chirping,will stop.
Nov 15, 2010 | Kidde 4618 Firex Hardwire Ionization Smoke...
Battery life poor
Check for cable corosion, and any bad ground or power on.
Dec 17, 2017 | Polar CS100
CP685AVR/BF685 Power Contro.
It is likely the battery. These batteries are designed to last 3-6 years in a UPS. The good news is that if it is the battery, it is completely user replaceable and you'll have a Cyber Power unit that works just like new with a new battery. What may have happened is that the battery was weak, and you may have had a slight dip in the AC power. This caused the Cyberpower unit to switch over to the weak battery which couldn't handle the load. The unit then turned off. When you press the "ON" button, the unit will go through a self-test that checks all of the components and the unit will not turn on and be functional unless all of the components come back with a PASS, including the battery. If possible, test the battery with a voltmeter, it should read around 13.5, but not lower than 11.5v DC. However, with the unit over 3 years old, it almost certainly the battery. Here's a link to a replacement battery for the CP685AVR: http://www.batteryinternational.com/cyber-power-cp685avr-ups-battery-ups-batteries-f1.html
Hope this helps.
Jun 28, 2009 | CyberPower (CP685AVR) UPS System
Batteries run down too quickly
hello there,
is the battery that you are using is new? how old is the unit?
first it is better to try to change or use a new battery on the unit, it seems that you have a weak & faulty battery on the unit.
let me knw
May 31, 2009 | Sony Cameras
'Battery' outlet dead.
Hi There, Its definately the battery. The batteries can be replaced.
Nov 05, 2008 | CyberPower OfficePower 650SL UPS System
HP 32sII Calculator Logo
369 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
