Question about Leviton Trimatron Rotary Dimmer 6602-i Lot Of 50
Leviton 057 dimmer 2 black and 1 green wire in a
Leviton 057 dimmer 2 black and 1 green wire in a two way how do I wire it?
I want two dimmer switch parrel they both fhave two black and one green how fo you wire it up
Posted on Jun 15, 2010
  • 672 Answers
One black to incoming (hot) black wire, one black to out going black wire , green to bare ground wire in wall box or attach directly to the box.
Posted on Sep 29, 2009
  • EDWARD AMARO Jul 01, 2013
    ONE BLACK INCOMING HOT AND ONE BLACK OUT GOING ONLY
3 Suggested Answers
  • 744 Answers
SOURCE: I have a leviton 057 with 2 black wires and 1
See this link:
http://www.easy2diy.com/cm/easy/diy_ht_index.asp?page_id=35720237
Be careful
Posted on May 10, 2009
house has a black and a white line and a ground commper, dimmer has two black and a green
How do I know which blck lead goes to white and which goes to black? One lead is shorter than the other.
Posted on Aug 09, 2009
I'M REPLACING AN OLD LEVITON ROTARY DIMMER WITH A LUTRON PADDLE DIMMER. THIS IS A 3-WAY SWITCH. THE ROTARY DIMMER HAS 2 BLACK WIRES, 1 RED, AND 1 GREEN. THE NEW DIMMER HAS 1 BLACK WIRE, 1 RED, 1...
with a three way switch like this, you will have two traveller wires and a common wire. Look in the instructions for the switch or on the back of the device itself to see if there is a wire labeled "common" or "com". This common wire from the old switch hooks up to the common wire on the new switch. I did a bit of searching on the leviton 6602, but couldn't find anything specifically about the three way version (I would venture to guess, however, that the red wire on the old switch is the common). The common on one of the three way switches will always be a constant hot (or power) wire...the common on the other three way switch will be the "switch leg" or the wire that connects directly to the light. The two travellers go to the other two wires. Check the pamplet that came with the lutron device, it should show which wire is common and which are travellers.
Sep 24, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
I am wiring 12 Leviton dimmer switches to light up a series of 12 halogen under cabinet hockey puck lights. I am bring power to the first switch through a 14-2 wire and using a pigtail to conduct power to...
You cannot wire dimmers in series and expect circuit to operate.
Problem is not 100% clear. Add a comment and include more information.
1) You have 12 dimmers.
Each dimmer has 2 black wires and a green ground wire.
The 2 black wires tell electrician that the dimmer wires are reversible.
One black dimmer wire connects to Hot from breaker, and the other black wire connects to wire going to Load (halogen lights).
If power passes through each dimmer going to next dimmer, the circuit will not work.
2) Unknown what you are replacing. Are you replacing 12 switches with 12 dimmers? Or maybe replacing 1 switch with 12 dimmers.
Number and type of devices being replaced is not known. And wires to each of these dimmers is not known.
3) You have a single 14-2 wire going to all 14 dimmers? Or does each dimmer have a different 14-2 wire?
4) You want to wire dimmers in series? So you want power to flow through one dimmer and control next dimmer?
You cannot wire dimmers in this manner and expect circuit to operate.
You can wire ordinary switches in series, but not dimmers.
5) Typically dimmers and switches are wired in parallel.
The Hot wire connects to one wire on each dimmer.
Since your dimmer has 2 black wires, the hot connects to either black wire on dimmer.
Then a jumper wire is added to connection, and the jumper wire carries power to next dimmer, and so on.
In this manner, each dimmer receives 120V potential. And then wire going to load connects to other black wire on each dimmer.
Sep 10, 2011 | Leviton Electrical Supplies
I have a leviton dimmer and no instructions. It has two black wires and one green wire. how do I hook it up as a single pole dimmer?
One black is will hook up to one of the black wires inside the switch box in the wall and the other will hook to the other black wire in the box, The green will connect to the bare copper wire which is the ground wire.
Sep 28, 2010 | Leviton Decora Light Dimmer Switch
Replace 3 way dimmer but different color wires how to connect?
you will want to make the following connections
existing-black wall to black dimmer now connects to red dimmer
existing black wall to red dimmer now connects to black dimmer
existing red wall to black dimmer now connects to red dimmer
Green wire connects to bare copper wires in wall
Apr 26, 2010 | Leviton Toggle Touch Dimmer - TGI06-1LB -...
Have a Leviton dimmer with red, black and green wire. House wiring is black and white wire and copper wire. I assume that copper wire is ground and connects to green wire but I am not sure where the white...
You are correct in assuming green is the ground and connects to bare copper wire. Black is always the HOT wire and should be attached to the black wire. Red wire connects to white wire.
Sep 13, 2009 | Leviton Toggle Touch Dimmer - TGI06-1LB -...
May 07, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
I have the Trimatron Dimmer switch to install,
one black from the dimmer to black. the other black from the dimmer connected to red. the green connected to the bare wire.
Mar 20, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Need help hooking up a single pole Leviton dimmer switch
hook up the red to red
black to black
green to bare wire
tie white wire to other whites in back of switch box in the wall.
If no whites in there cap it off with a wire connector.
Oct 27, 2008 | Electrical Supplies
Leviton Trimatron Rotary Dimmer 6602-i Lot Of 50 Logo
1,626 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
