Question about Epson Stylus CX4800 All-In-One InkJet Printer
We have dropped a tiny SD card into the paper slot of our Epson Stylus CX7800. It is not visible and does not "shake loose" and we really cannot tell where it is lodged. It does block flow of paper. Where can I find how to disassemble our printer to remove the card? I prefer not to have to buy a complete service manual for this task. Any help would be appreciated. Thanks.
  • Epson Master
  • 419 Answers
I'm afraid a Service manual is really the only way you're going to figure out how get the necessary access.
2manuals.com have a copy for $12.99 so it's really a question of how much you value your sanity.
One small tip for identifying where it might be though... try feeding paper in and see if where the paper bunches up most. That's usually a good indicator of where the blockage is hiding.
Best of luck,
Martin
Posted on Sep 30, 2009
EPSON STYLUS CX 7800 HOW DO I ALIGN THE HEADS??
1. Turn on the Epson Stylus CX7800
2. Load several sheets of paper
3. Windows: Right-click the printer icon on you taskbar (in the lower right corner of
your screen). Select Print Head Alignment.
Macintosh OS X: Open the Applications folder and select Epson Printer Utility.
Select your Expson Stylus CX7800 in the printer list, click OK,
and select Print Head Alignment.
Jan 15, 2011 | Epson Office Equipment & Supplies
Keeps jaming on the right every time
Follow this step to clear the jam
press the diamond shape button start button to eject the jammed paper. If the jammed paper is not ejected, go to the next step.
if the paper is stuck near the sheet feeder or output tray, gently pull it out.
If the paper is stuck inside Epson Stylus CX7800, press the power on button to turn it off. Open the scanner and remove any pepr inside including any torn pieces. Do not pu;; it backward beacuse this can damage the sheet feeder. Close the scanner, then turn the epson stylus CX78oo back on.
Nov 17, 2010 | Epson Stylus CX7800 All-In-One InkJet...
What can i do if i lost my install cd for my epson stylus cx7800
Just go to Epson's website and you could download a copy of the drivers, and any other software that was on the cd.
Mar 06, 2010 | Epson Stylus CX7800 All-In-One InkJet...
THE EPSON STYLUS CX7800 KEEPS SAYING THERE IS A PAPER JAM, BUT IT'S NOT. IT TRIES TO PULL THE PAPER THROUGH, THEN STOPS. IT DOES NOT ENTER FAR ENOUGH TO EVEN BE JAMMED. IT APPEARS THAT IT IS TRYING TO PULL...
The sensor lever was stuck and still blocking the sensor and that is the reason why it always say paper jam.You have to dismantle your printer if you do,you can find and trace the sensor where the paper is being inserted,most probably it is near the pick up roller (it is the one that gets the paper).
Sep 17, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Sd card in epson cx7800 printer not being read by iphoto on mac
You probably need to re-install the Epson drivers. There is a driver for the printer, but there may be another one just for the sd card reader. Re-install it either from the disks that came with the printer, or download the most recent drivers from epson.com.
Jul 13, 2009 | Apple Computers & Internet
Need xp 64 bit driver for Epson Stylus CX7800 all in one printer
Thank you for choosing epson.
Note that you have to uninstall the existing epson scan software and epson printer software on your computer first.
Log on to support.epson.com to get the proper driver for your printer.
These are the drivers that you need to install:
TWAIN Driver and EPSON Scan Utility v2.68A
epson11620.exe
Printer Driver v6.51
epson12767.exe
You can also click on the link below:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=58773&prodoid=56291070&infoType=Downloads&platform=Windows
Please inform me if you need further assistance.
Sherlyn C.
May 06, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Epson cx7800 paper continually comes out - not printing
you need to download the scc to reset your printer if you can not find the software let me no and will give it to you
Oct 21, 2008 | Epson Stylus CX7800 All-In-One InkJet...
My epson cs7800
I had the same problem and found a small spring was loose and interfering with the paper. The Spring was on the right side as you look at the printer, near the bottom of the paper feeder. I took it out and it works fine, for now.
Jun 15, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
105 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
