Device doesnt show in 'my computer'
I have a 250gig external drive. The computer loads the USB drivers and says that it is ready to use, but the device doesnt appear on 'my computer' I have tried different USB slots and different computers with the same results
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 29, 2009
  • 68 Answers
This happens when there is not adequate voltage supplied to the external hardisk
try using a friends adapter or a different usb cable
Genx flash memory
Click Start, type Device Manager in the Search box
Click Device Manager from the returned list.
Click Disk Drives from the list of hardware
Right-click the USB external hard drive with the issue, and click Uninstall.
After the hard drive is uninstalled, unplug the USB cable.
Wait for 1 minute and then reconnect the USB cable. The driver should automatically load
Check for the USB drive in Windows Explorer
Note: Connecting your USB external hard drive into a non-powered USB hub can cause a lack of enough power to operate the external drive. Instead, plug it directly into your computer.
Sep 29, 2013 | Electronics - Others
Upgraded from windows 7 to windows 8 ,now storage device not showing.
Have you tried to shut down the computer, unplug the usd external drive, reboot the computer, plug in the USB external HDD the should apply the driver. That said, Have you tried a Thumb Drive or any other USB device in the USB ports? It's a common problem when upgrading a OS that Hardware issues popup. Open the Device Manager, Is your USB controller working? Enabled? Any other devices in error? Unknown devices? Use the Win 7 drivers for your computer found on the computer manufacturer's website. Change the compatibility on the driver for Win 8.
Jan 11, 2013 | Western Digital 1TB WD ELEMENTS USB...
My computer doesn't show the external drive
Try plugging the hard drive to a different usb port, if that doesnt work its possible that you may need to update the usb drivers.
Dec 11, 2011 | Fantom Computers & Internet
My computer is not recognizing my LaCie external hardrive
First cehck whether your computer is able to recoznize other USB storage devices or not. If you see that it is not recoznizing other USB storage devices. Then you need go to your Boot Up screen, the screen that opens when you restart your PC.
Then go to the USB section and enable USB drive.
If this also does not resolve your problem, then try installing USB drivers on your PC, You can install them from the website : http://www.softwarepatch.com/tips/usb2-driver.html
I hope this resolves your problem.
Apr 20, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
External drive doesnt show on computer wen i plug
install proper driver for your external device
Jan 18, 2010 | Electronics - Others
My maxtor basic external model STM905003EHM301-RK cannot load by computer...plz help me..
All you have to do is plug in the device into the USB Port, and connectthe drives AC Adapter if neccesary. Thats all there is to it. The driveyou plug in will show up as a hard drive in My Computer
if problem persists try loading the drivers for disk that you can download from www.download.com
May 01, 2009 | Computers & Internet
USB drive problem
I had a client with this same issue. However, her issue was that the top left USB port would only accept flash drives. Your external harddrive is probably not getting enough power from your USB port. Try using two USB ports (you can get a connector for this) to power up the external harddrive.
Apr 06, 2009 | HP Compaq nx6325 Notebook
Western Digital MY BOOK 500gig - Drive does not appear
Check the driver letter assignement, and make sure there is no conflict on that (happened to me on my laptop as well).
I found out by reading this: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Definitely don't format if not required, you can first try to restore the MBR.
Mar 01, 2009 | Western Digital My Book Essential 1TB...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
Lacie 160 gb hard drive problem
Did you mess with any Config Files?
Sep 04, 2007 | LaCie (300740) 160 GB Hard Drive
Computers & Internet Logo
384 people viewed this question
David Payne
David Payne
