Question about MicroBoards Orbit Pro DVD DVD-R Burner
Drive belt failure - MicroBoards Orbit Pro DVD DVD-R Burner
    Top Expert:
  • MicroBoards Master
  • 76,164 Answers
U can buy these belts on line, try ebay.
Posted on Sep 29, 2009
What would cause your car to stop running while driving?
failure of the timing belt
failure of either cam/crank position sensor
immobilizer cut in
battery failure / broken battery lead
blown ING fuse
out of fuel
pump failure
overheated
Oct 11, 2015 | Ford Expedition Cars & Trucks
Ineo +200 status p 6 and p 21
P-6 : Cyan imaging unit failure
P - 7:Magenta imaging failure
P -8 :Yellow imaging unit failure
P -9:Black imaging unit failure
Select Imaging Process adjustment - D Max Density and if the setting value is negative readjust.
Check the drive transmission portion of the imaging unit and correct as necessary,clean theIDC registration sensor windows if dirty,clean the contact of the imaging unit connector if dirty,check the high voltage connector for proper connection.If necessary change the image unit or the image transfer belt unit.
P -21 : Color shift test pattern failure.
Wipe clean the surface of the transfer belt with a soft cloth or change the image transfer belt unit if the transfer belt is damaged.
Feb 21, 2013 | Konica Minolta Office Equipment & Supplies
Turntable not working
Possible failure of the drive belt or the turntable motor. Remove the bottom cover to confirm failure of the drive ,belt or if the motor has failed- check power to the motor when the microwave works if the motor tests OK.
Jan 10, 2013 | GE SpaceMaker Microwave Ovens
T914 "drive motor error 2"
1)VSD(variable speed drive) MICROPROCESSOR eprom/sram failure: Exchange VSD board.
2) Belt speed pickup,failure in the speed pickug, to due motor, wiring or controller board.
sincerely.
E.CUADRA
Sep 12, 2011 | Nautilus Tc 916 Treadmill Vsd Board
85 chevy celebrity. replaced alternator. that one squealed 2. got another. still hear a squeel. does not squeel when belt is off.
ALTERNATOR BELT NEED ADJUSTING AND REPLACING IT GLAZED. WHEN DRIVE BELT GET GLAZED SHINY CAUSE IT TO SLIP AND SQUEAL.REPLACE ALTERNATOR DRIVE BELT. AND ADJUST IT DRIVE BELT TENSION BY TIGHTEN THE UNTIL YOU CAN PRESS DOWN ON THE BELT IN THE LONGEST RUN. YOU NEED TO PRESS DOWN BELT AND GET A 1/4 TO 1/2 INCH DEFLECTION IN BELT.THE BELT CANT BE TOO TIGHT WHERE WHEN YOU PRESS DOWN AT IT WONT GIVE IN NONE TOO TIGHT, WILL CAUSE PREMATURE ALTERNATOR BEARING FAILURE IF DRIVE BELT TOO TIGHT.
Apr 18, 2011 | Chevrolet Celebrity Cars & Trucks
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Whats a difference between timing belt and drive belt , for my 2004 Elantra Hyundai cernter is asking to change the drive belt and flush the Hyd oil, car has 53,000 miles on it
a drive belt refers to belt driven items like alternator, power steering, water pumps and the like.
A timing belt is cogged to precicely hold the relationship between the crankshaft and the valve train. Timing belts are usually located within covers, as the loss or damage to this belt exposes engine damage and failure.
May 22, 2010 | 2004 Hyundai Elantra
Belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
Feb 20, 2010 | Proform CrossTrainer Treadmill
Yard Machine tractor drive deck belt failure
i need a diagram of tensioner springs on yard machine deck 1998 42inch
Aug 11, 2009 | Yard Machines Red Edger
How to change 1999 nussan quest ac belt
http://groups.yahoo.com/group/villagerquest/
Belt —A/C Removal
  1. Remove the A/C compressor drive belt.
    1. Loosen the A/C compressor drive belt pulley tensioner bolt.
    1. Loosen the A/C compressor drive belt idler pulley adjustment bolt.
40f6b66.gifInstallation
  1. sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Incorrect drive belt installation will cause drive belt failure.
    NOTE: Inspect the pulleys for warping or abnormal wear.
    NOTE: Make sure drive belt is properly installed on each pulley.
    To install, reverse the removal procedure.
    • Adjust the A/C compressor drive belt. For additional information, refer to Belt Adjustment—A/C .
Aug 10, 2009 | 1995 Nissan Quest
MicroBoards Orbit Pro DVD DVD-R Burner Logo
65 people viewed this question
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
