Question about Canon PowerShot A630 Digital Camera
Canon PowerShot A630 camera won't power on, even with fresh batteries / cleaned terminals.
t00nz
  • 4738 Answers
SOURCE: Canon Powershot A630 problem
The LCD screen may be overtaxing your batteries, resulting in shutdown. Are you using alkaline batteries, or worse yet "super heavy duty" batteries? If so, some brands of regular batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. Performance varies by brand and shelf life of the batteries (how long were they on the store shelf before you bought them? Their expiration date may be listed on the package.).
Digital cameras for the most part should only be used with rechargeable NiMH batteries. Many retailers sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on May 17, 2008
  • 16 Answers
SOURCE: A630 clicks and wont take picture. Stays in preview mode.
Do you mean you are expecting it to show the photo that you just took for a few seconds before it goes back to preview mode? There's a menu setting which I think is called "Picture Review" and you can set it for something like 0, 2 seconds, 5 seconds, something like that.
I hope that was it.
-Vince
Posted on Oct 01, 2008
SOURCE: canon powershot a630 lens is stuck
My lens was stuck inside the camera and would not come out when I turned the camera on. I could hear a sound but nothing was happening with the lens. I used a dental pick (small sharp pointed object) to pull at the lens and it came out and seems to be working fine. Just tried it a couple of hours ago and It seems to be OK.
Posted on Feb 21, 2009
t00nz
  • 4738 Answers
SOURCE: Remove battery door of Canon A630
This is an old A70, but the way it's done is very similar as I don't think this has changed much over the years. It's a pin design that you have to push out with a stiff unbent paperclip. You push in on the side with the smaller hole. To access the pin you'll need to remove the front and back case covers. See the following:
http://blog.thustra.com/2007/03/canon-a70-ir-modification.html
Posted on Jun 20, 2009
SOURCE: Canon powershot A630 blinking flash graphic
You have to unscrew the left side of the camera (if you're looking at the back of the camera, the side that is right beside the flash). Then, at the very top, with a tiny screw driver, just gently tap the black flash compartment and it should work after that. I've had the flash problem twice in the past year and both times I got it to work again by taping on it. Hope it helps!
Posted on Jun 29, 2009
The off and on button seems to have quit operating. It needed new batteries. We installed them and then we are unable to turn the camera on.
As a first step towards resolving your issue, we recommend you restore
the camera's default settings. You can reset all of the menu and button
operation settings to default except for Date/Time, Language, and Video
System. To reset these settings, please follow these steps:
1. Take the memory card and battery out of the camera for 20 minutes.
2. Please use a clean pencil eraser to rub the contacts on the battery.
Please do not store the batteries in the camera for travel. The
batteries will discharge even if the camera is not powered on.
3. Place a fresh (or fully recharged) battery in the camera.
4. Turn the camera on.
5. Put the camera in picture taking mode. Ensure the display is on.
Jul 20, 2010 | Canon PowerShot A630 Digital Camera
I have a canon A630 and the flash just stopped working- help today is my daughters graduation!
This model does experience various "lock up" or "freeze" problems. Here's how to fix it.
You need to restore the cameras settings. You can reset all of the menu and button
Jul 02, 2010 | Canon PowerShot A630 Digital Camera
A630 will not power on. Says batteries are dead.
You have to clean your battery compartment contacts. To do this Dampen a Q-Tip swab with rubbing alcohol and clean the contacts well. Also you'll want to clean the battery and charger contacts as well. Thank you, Dana
Oct 05, 2009 | Canon PowerShot A630 Digital Camera
Canon PowerShot A630 power problem: NiMH batteries no longer work
I dont agree, I have tried several different batterie types and the batteries are draining almost instantly with the camera and they are not actually being drained. I think the camera itself is at the end of its life...as I have used rechargeable batteries for the last few years and now they wont even show as being charged on the camera. It stinks Im in your same spot now...no batteries are lasting even the brand new lithium ones...it has nothing to do with the battery "juice" but something with the canon supply power not recognizing/recieving the juice. Im not a canon expert, but I think the problem is more than the battery here Steve and im confused at the solution as well.
Apr 02, 2009 | Canon PowerShot A630 Digital Camera
I hope that was it.
-Vince
Oct 01, 2008 | Canon PowerShot A630 Digital Camera
May 16, 2008 | Canon PowerShot A630 Digital Camera
Battery drains quickly
"It shouldn't do that." But you already know that. Even with everything "on" in the camera it still shouldn't do that.
I think you need to try a) alkaline batteries and b) new NiMh batteries. If it still persists then your camera has a deeper problem and needs to be sent in for repair.
Dec 03, 2007 | Canon PowerShot A630 Digital Camera
Canon PowerShot A630 Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
