Question about Cadence Weslo 825 Treadmill Walking Belt
The walking belt slips to the left when walking
There are two allen bolts (one on each side) at the end of the machine. These bolts adjust the tension on the belt. If they are not adjusted evenly the beft will gradually shift of the more loose side.
Posted on Sep 29, 2009
Walking belt won't center and drifts to the left...sometimes seems to slip
http://www.youtube.com/watch?v=pStE-LlgIG4&feature=related
Please see this video for adjustment, you can see too another videos in the same web page from youtube.com such adjusting the deck belt,etc.
sincerely.Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
Dec 11, 2011 | Exercise & Fitness
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
Belt slips and somtimes stops on me while walking.
hi. if the belt slips and stops when your walking its a sign the you may need a replacement belt. and if you smell motor burning after you have been on for a while that is a sign that a/ you have no oil left and b/ your motor is slowley packing up.hope i have helped.
Nov 11, 2010 | Proform 695 LT Treadmill
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
Jul 15, 2010 | Treadmill Doctor Weslo Cadence Dx10...
The walking belt on this Lifestyler Expanse 8.0 Treadmill has slipped towards the left side; folding the left side of the belt over itself.
I'm sorry to say that the belt is toast and needs to be replaced. I would also check the end caps I believed it is a one piece unit that the belt tension bolt is attached and the left side had cracked and cause this problem. Call Icon Fitness @ 1-800-999-3756 with locating the proper parts and pricing
May 28, 2010 | RTO Lifestyler Expanse 8.0 Treadmill...
I've got an i-run machine and when I tried to
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Then,plug in2_bing.gif the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Mar 01, 2010 | Reebok New York Giants Eli Manning Jersey
My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Feb 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
The belt seems to slide to one side on my Proform Crosswalk 380. How do I fix it?
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Feb 27, 2010 | Proform 380 CS Treadmill !
Everything seems to work fine except a small slip in the track about every 30 seconds or so. Is there something that needs to be tightened?
The walking belt may be too loose. If you have made recent adjustments, lubricated, or had repairs, a belt can slip if not tightened. The belt can slip if you have too much friction or if the belt has been recently lubricated. If lube does not help your problem and you have exhausted all other possibilities, the walking belt is most likely worn out and must be replaced.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
Have a 4.9 treadmill and cant get it to adjust if i loosen bolts in back it slips if i tighten bolts on motor it quits pulling when i put weight on it can you help
Ok I really need more info but let's take a stab at it. The bolts in the back of the rear roller adjust the belt right and left. It also tightens and loosens. Ok there is also a drive belt from the motor that needs to be tight. Generally you should be able to twist the drive belt about 45 degrees. If it's more than that it probably needs to be tightened. If this is loose it will affect the walking belt the same as the walking belt being loose. So when your walking belt is slipping, make sure you tightened the right belt. Tightening the wrong belt can lead to other problems. Tightening the walk belt with the rear roller- turn both bolts clockwise equally to tighten. Remember the walking belt will travel to side with least tension. So to center belt, adj left or right side to fine tune. If belts are adjusted properly and machine stops when you walk on it, you have other issues. Could be the deck ( the board under the belt) and belt or the motor.
Nov 17, 2009 | Proform 6.5q Treadmill Walking Belt
Cadence Weslo  825 Treadmill Walking Belt Logo
319 people viewed this question
Top Cadence Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Sportsmith LLC
Sportsmith LLC
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
