Question about Christie Roadster X9 Multimedia Projector
I need Modules LVPS (Low Voltage Power Supply)
I need
Panel driver
with price ??
  • 2,237 Answers
You're going to have to go through christie to get that. they don't sell parts through other distributers
Posted on Jan 06, 2010
How do I know which power supply to change on my printer?
normally it's the LVPS.
Make sure the metal contacts on the toner cartridge and the ones that touch the cartridge are clean
Jul 18, 2014 | Dell 5100cn Laser Printer
Error 931
In most cases this error has something to do with the printers LVPS (Low Voltage Power Supply ).
If the printer is connected to power surge, try to connect it to an outlet from the wall. Do an An AC power check - check the AC line voltage at the end of the AC line cord. If the Ac line cord is incorrect, replace the cord.
Also check if the cord is in good condition. if not, replace the cord. If you still get the same errror, you may need to replace the printers' LVPS.
For further assistance assistance please contact Lexmark Technical Support.
Feb 09, 2012 | Lexmark C750 Laser Printer
Lexmark c770 dead
Please try reseat power cable. If this does not resolve the issue, you may need to replace the LVPS ( Low voltage power supply) on your printer.
For further diagnosis, please contact Lexmark Technical Support Center at 1-800-539-6275.
Jul 14, 2011 | Lexmark C770n Laser Printer
My Lexmark C544dn laser printer just up and died - I had just put in new paper, hit print on my Mac and when nothing happened, I realized the machine was off. Yes, I checked the power cord at the machine...
Please try to do the following steps
• Check the AC line voltage. Is the line voltage correct? If not connect it to the correct line voltage
• Check if the AC line cord damaged. If damaged replace the AC line cord
• Is the LVPS cable correctly connected at JLVPS1 on the controller board? If not Reconnect the cable at JLVPS1
• Turn the printer off, and then on. Does the problem persist?
• Damage to the printer is possible. Be careful to touch only one conductor at a time, Rest the probe against the connector to steady it.
• Replace the LVPS - Low-voltage power supply (LVPS)
Please contact Lexmark Technical Support for further assistance.
Mar 26, 2011 | Lexmark C544dn Laser Printer
My printer doesnt work it doenst switch on at all
If printer doesn't work and it doesn't switch on, I assumed that there is no power at all on the printer. Check the AC line voltage if it is correct.
Unplug the printer. Remove the LVPS/HVPS, and check the fuses for continuity.
• If open, then replace the LVPS/HVPS.
• If not open, then check the switch continuity across its conductors with the switch on.
Turn the switch off. Plug the AC line into the LVPS/HVPS, and switch unit on.
Please try reseat power cable. If this does not resolve the issue, you may need to replace the LVPS (Low voltage power supply) on your printer.
For further assistance, please contact Lexmark Technical Support
Feb 07, 2011 | Lexmark E260 Laser Printer
Bizhub C203 screen and machine is dead but lights come on.
its probly a LVPS low voltage power supply. i can get the part # if needed
Nov 05, 2010 | Konica Minolta Bizhub c203 Copier
What is the error message you are getting with the new fuser. Is this the same error you were getting before changing the fuser? If you changed the fuser because the old one was just at EOL ( end of life) but did not give you an error, have you tried to reinstall the old fuser.
It is possible that the new fuser was damaged in shipping, or not properly seated.
If both the new and old fuser give the same error message, then yes, I would agree that the LVPS would be the next part to replace, however, if they have different errors, then you probably have 2 bad fusers ( or one that is EOL, and one that was received damaged).
Before changing the LVPS, make sure you follow the steps below prior to the LVPS steps.
as far as where to purchase it if you do in fact need one, you can always do a google and ebay search for "Dell 5100cn LVPS".
I can provide you with replacement instructions if it comes to that.
See below for the actual troubleshooting needed for the fuser.
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
Oct 23, 2008 | Dell 5100cn Laser Printer
E197 code
It´s broken LVPS assy (low voltage power supply). We have had several of those.
Marko
Aug 27, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Lvps
Remove the fuser assembly
Remove the rear cover
Remove the fuser top duct screw and disconnect tab
Remove the top duct
Remove the redrive belt cover duct
Remove fuser left duct
Remove fuser bottom duct
Swing lever and disengage VTB shaft
Remove the fuser drive assembly screws and remove the fuser drive assembly
Disconnect the J33 and J35 cables from the system board
Remove the four LVPS screws from the rear of the printer
Remove the right rear cover screw
Remove the screw from the top of the LVPS and remove the LVPS from the
printer.
Installation notes
When installing the new power supply, set the voltage range switch to the proper power setting for the
geographic area you are in.
Be sure to set the voltage range selector switch (A) on the LVPS to the proper setting.
Aug 25, 2008 | Lexmark C760 Laser Printer
IBM Infoprint 1352 won't power on
LVPS (low voltage power supply).
To get to it remove the right side cover (to do this, take the toner cart out and you'll see a screw on the inner right side, remove this. Remove the rear cover, the if you look through the top of the metal frame on the inner right side you'll see another screw, remove this. the cover will then come off.
Remove fuser assembly
Remove the LVPS mounting screws (2) from the rear of the bottom pan.
Pull the LVPS assembly far enough out from the right side of the printer to disconnect the fuser lamp cable.
Warning:
The LVPS assembly may be difficult to remove from the printer. Do not use excessive force in the removal.
Remove the LVPS access plate.
Disconnect the interconnect card cable from the LVPS.
Remove the LVPS.
Aug 24, 2008 | IBM Infoprint 1352 Laser Printer
Christie Roadster X9 Multimedia Projector Logo
126 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
