Question about Mach Speed P4MBMS Motherboard
Hello, Trying to update this motherboard, now cpu celeron 3.20G 533ghz and would like to update to pentium 4 3.6G 800ghz that the user's manual says is doable. The problem is the motherboard will not reconize the pentium cpu. All i get is a black screen. Cay you help? Thanks, Greg
  • Mach Speed Master
  • 4,806 Answers
Always remember that when you add new hardware like a processor or faster memory you have to clear the CMOS to reset the BIOS to defaults so it will recognize the new hardware. Sometimes you have to do this with hard drives particularly SATA drives.
On the motherboard, near the motherboard battery look for a small coloured plastic jumper. If your motherboard has one it will be marked as CLR_CMOS. Just move the jumper to the other position and press the on/off button. That will clear the CMOS.
If you don't have a CMOS jumper then remove the power cord from the back of the computer and take out the BIOS battery for half an hour or so. Replace the battery and plug in power. Turn the computer on and hopefully the the computer will boot and you will see a splash/post screen. If you do remember to set the correct date and time in the BIOS utility.
If your still not getting a post screen go back and check the processor is compatible with the motherboard. Check that the processor is locked in the socket properly and also check to make sure your system memory is seated properly.
Post back if need anymore advice.
Reagrds.
Posted on Sep 29, 2009
Cpu suport
Going with problem heading stating ->
IBM 73P0595 motherboard > CPU Support > and previous problem statement ->
"I have updated my processor from INTEL Pentium d 820,2800mzh 1500mzh to INTEL Pentium d 945,3400mzh....."
Let's take a look at the IBM 73P0595 motherboard specifications, first;
http://www.epinions.com/specs/IBM_System_Boad_W_O_POV_10_100_73P0595_Motherboard?sb=1
http://www.ebay.com/itm/Lenovo-73P0595-ThinkCentre-M50-A50-Motherboard-SOCKET-478-2-4GHz-Intel-CPU-/200870757822?pt=Motherboards&hash=item2ec4d485be
A) Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
B) Intel 865G motherboard chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_chipsets
The Intel 865G motherboard chipset DOES NOT support dual core processors.
Does NOT support an Intel Pentium D; 820 OR 945
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Smithfield.22_.2890_nm.29
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Presler.22_.2865_nm.29
Those two processors also use the LGA 775 processor socket.
(Socket T,
http://en.wikipedia.org/wiki/Socket_T )
What did you base your CPU support on?
Was it the fact that the Intel 865G motherboard chipset, will support Intel Celeron D?
http://en.wikipedia.org/wiki/Celeron_D#Celeron_D
The Intel Celeron D is NOT a dual core processor,
"The Intel Celeron D processor works with the Intel 845 and 865 chipset families.
The D suffix actually has no official designation, and does not indicate that these models are dual-core.
It is used simply to distinguish this line of Celeron from the previous, lower performing Northwood and Willamette series, and also from the mobile series, the Celeron M......"
Not the IBM 73P0595 motherboard we're talking about?
OK.
Let's just base it on the statement that you tried to upgrade, from an Intel Pentium D820 to an Intel Pentium D945,
http://www.fixya.com/support/t13549945-update_intel_pentium_d_945_procesor
What motherboard are you using?
Motherboard in a HP Compaq DC7600 Desktop PC?
http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Scroll down to the bold subheading -> Processor and Speed
Intel Pentium D820 at 2800MegaHertz (2.8GigaHertz),
with 800MegaHertz Front Side Bus, is supported.
(800MHz FSB)
Probably came with your computer, huh?
Intel Pentium D945 at 3400MHz (3.4GHz), with 800MHz FSB is supported also.
This can be seen by the specifications of the motherboard chipset, also. The Intel 945G motherboard chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_chipsets
Scroll down to 945G in the left column. (Last one listed in chart)
Apparently you just needed the 786D family Processor Microcode Update, or did that not work out?
Awaiting reply,
Regards,
joecoolvette
(How did I come up with the HP Compaq DC7600, anyway?
Did you add it in a Comment, and it has been removed, or what?
!O_O! )
Jan 02, 2013 | IBM (73P0595) Motherboard
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
Jul 08, 2011 | Intel DG31PR Motherboard
What CPU is compatible with the motherboard GIGABYTE GA-065P-DS3?
The following CPUs are compatible:
Core 2 Extreme Core 2 Quad Core 2 Duo Pentium Extreme Edition Pentium D Pentium 4 Extreme Pentium 4 Celeron 400 series Celeron D
You may need to update your BIOS to get full support for all of these CPUs. Literally dozens of CPUs are supported by your motherboard.
Feb 22, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
What kind of cpu do i need ? i have asus p5nd2-sli motherboard with no cpu in it
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Seems that you need Socket LGA775,and CPU: Pentium 4, CeleronD, Pentium D, Pentium Extreme Edition. For more Details go here:
http://www.google.com/products/catalog?hl=en&q=p5nd2-sli+motherboard&cid=13414569805758042878&os=tech-specs
Nov 16, 2010 | ASUS P5ND2-SLI Deluxe Motherboard
What CPU to use?? Celeron or P4 and up to what speed?? 1.7Ghz or higher?? Thanks
Hello!
First your motherboard have some limits, but if you can use both CPU, it is better right pentium 2,0 - 2,5 GHz, because Intel Celeron is a chiper ver. of pentium.
It is important what is your motherboard, how much RAM you have, and fsb on motherboard.
For speed isn´t enough only best CPU.
Nov 07, 2009 | Computers & Internet
Will This Cpu fit my computer?
You can put the cpu in, its the same socket and the same pin as that one you have now. But you will probably not be able to use the 800Ghz fully since it is the motherboard who sets the buz speed and the cpu you using now haz the speed of 533Ghz.
About the RAM, you can have maximum 2GB of memory on that motherboard, thats all it supports. The momory type you can use is DDR PC2100/PC1600
All you need to know about your PC you will find here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07638&lc=en&dlc=&cc=us&lang=&product=85375
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 14, 2008 | Computers & Internet
Cpu compatibility
Hi Buddy,
Thanks For The request.
Heres Your Information:-
http://safemanuals.com/user-guide-instructions-owner-manual/ASUS/P5RD1-VM-_E#
This Is English Version Of your Motherboard. Just Click The pdf file and download. Open with adobe acrobat Reader.
Compatable With Socket 775 CPU. Pentium D. Pentium 4.Or Intel Celeron Processors. Your CPU should be fine on this Motherboard, Providing It has the correct Pins. ( Socket 775 )
Hope this Answers your Question.
Mike @ compurepair.
Mar 15, 2008 | ASUS P5RD1-VM Motherboard
Mach Speed P4MBMS Motherboard Logo
102 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
