Question about Brother MFC 8500 All-In-One Laser Printer
Brothers MFC-8500 - Front Panel Problem
Some of the buttons on my Brothers MFC-8500 have stopped working. I traced the problem to a dammaged flex citcuit board and need a replacement part - or a replacement front panel. Any suggesitons where I can get one?
Soulvisitor
  • 1113 Answers
SOURCE: Replacing front LCD panel
Looks easy to replace boy did you pick the wrong model, I've done this job, what a pain of a design, you just want to get to those four screws that hold that operations panel in, heres what needs to be done first, remove left rear corner covers(2) and disconnect wires cables that go to Doc feeder and scanner(27millon), unscrew and remove doc feeder, now you can take out scanner top with glass, from base to reveal screws for operations panel. flow chart below .. and dont order that part it is the LCD display only - you want number depends on country but i think the states is .LE8846001 , PANEL UNIT, MFC8840D FOR ASA/OCE not LG4383001 LCD
And dont swear when doing job remember your a qualified engineer!! have fun,
AC CORD
DRUM UNIT
PAPER TRAY
DX FEED ASSY(duplex)
(MFC-8840D/8840DN, DCP-8045D/
(3.5 (1) and (2) are contained.
DRIVER PCB ACCESS COVER
5
ACCESS COVER/BATTERY
7
ADF UNIT
9
PANEL UNIT
8
DOCUMENT SCANNER
p.s. the switch itself is a lot of the time ok it is the plastic arm part that breaks..
Posted on Nov 09, 2007
early1234
  • 871 Answers
SOURCE: Brother MFC 8500 Fax machine error "offline"
is your fax machine connected to the phone line? this usually indicates the connection status, thus, if your phone line is in...you wont have the "offline message".
hope this helps.
Posted on Jan 23, 2008
crayzeetrayn
  • 837 Answers
SOURCE: To find user's guide for a Brothers MFC 240C
Here is the link
Give me a FIXYA please .. thanks
Posted on Dec 07, 2008
  • 320 Answers
SOURCE: LCD Panel
have tried going in to the menu? there is aplace in the menue that controls the brightness on the lcd pannel. if that will not work you might have to replace the lcd pannel
Posted on Jan 24, 2009
  • 133 Answers
SOURCE: Toner replacement on Brothers MFC 7420
Open the front cover and try to pull it out strongly.
then use the duster to clean the machine.
then you should able to replace your cartridge easily next time.
mightbe too dirty or you use ODM toner? if yes that's the problem issued from.
Posted on May 22, 2009
Reset Drum life MFC 9440CN
Not sure if this Brothers is the same but normally open front were you install drum and toner, machine on depress, menu button or clear button, display will show 1 or 2 to tell
you to reset drum count.. hope this works
Mar 04, 2016 | Brother MFC Office Equipment & Supplies
Position of Touch Panel.
It's been awhile, but I think you go into the test mode then hit one of the hard keys (start, threader, reverse). I know there is a backdoor for this.
On newer Brothers you touch the screen and hold while powering on, but I'm not sure yours does it that way.
Oct 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
How do i reset drum unit life counter on the mfc 7840w
hello, i am going to ball park this, with machine on, open up front cover as if you are going to replace toner, press the clear button, on the display it may say, new drum press 1 for yes 2 for no, then close front cover. normally the drum comes with the instructions on this, but sometimes its missing, but also brothers web site has the info on this. i work on these alot so most of the resets are the same
Oct 08, 2010 | Brother MFC 7840W Printer
Can my brothers printer work only on black ink (MFC 465 CN)
I am afraid you cannot print if (any) one of the cartridges is empty. Here is a screen capture from the properties of my MFC. At the bottom of the picture it says in French : Le MFC arrêtera l'impression Couleur/échelle de gris lorsqu'une ou plus des cartouches d'encre sera vide.
What it say in English is as follows: The MFC will stop printing in Color/Gray scale when one or more of the ink cartidges is empty.
Open the properties of the MFC. Under "Advanced" Tab Click the Printing Defaults at the bottom left. At the bottom of the window that pops up you will see the information that I translated for You.
Jun 30, 2010 | Brother MFC295CNAll-In-One InkJet Printer
Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Feb 10, 2010 | Brother MFC 8500 All-In-One Laser Printer
Nov 18, 2008 | Brother MFC-7420 Laser Printer
Help
rest teh machine by shut off the machine and pull out the pluug. wait 2 minutes and plug in the power and turn on the machine.
May 29, 2008 | Brother MFC 8500 All-In-One Laser Printer
I do not know who to operate the scanner function on my Brother MFC-8500
You operate it with paperport software which comes with the fax or can be downloaded on brothers site.
MJ
Indy
Oct 24, 2007 | Brother MFC-8500 All-In-One Laser Printer
Brother MFC 8500 All-In-One Laser Printer Logo
16 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
