Question about Maytag MFI2266AE Side by Side Bottom Freezer French Door Refrigerator
Need reset code for maytag fridge MFI2266AEU. Just replaced control board and lights are blinking PEO OOO
My sticker is missing. What code do I use?
Posted on Feb 01, 2010
  • 3 Answers
I was told there's a code on the inside of the door where the serial number is. How do you change the code?
Posted on Oct 25, 2009
  • jehardy Oct 26, 2009
    Try this:
    Here is a solution I found for my fridge from another site.
    http://www.justanswer.com/questions/2ce1...
    I had to change the Door Alarm button to temp alarm for my fridge Maytag model MFI2266AEW. See if it works for you, it worked for me. I had nothing flashing at all and had to change it to zero but all you need to do is change it back to whatever is on your fridge. My code was inside the fridge, after the word code. It was 4 digits long.
  • fink6 Mar 30, 2011
    Press Door Alarm and Freezer "-" at same time, then release Door Alarm while continuing to hold Freezer "-" until PE shows. Press Freezer "-' again so PE _ _ _ _ shows. Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring each number to "0". Should read PE 0 0 0 0. Press Freezer "-" and hold until numbers flash. Unplug for 45 seconds, no more than one minute. Look inside refrigerator for serial sticker. On that sticker, to the right of the serial number, find your CODE # # # #.
    Plug in the regrigerator. Press Door Alarm and Freezer "-" at same time, then release Door Alarm and continue holding Freezer "-" until PE _ _ _ _ shows. Using same method above to bring numbers to 0 0 0 0, now enter your CODE numbers in those places. Press Freezer "-" and hold until numbers flash. Unplug regrigerator for 45 seconds. You have just reset your door panel. Plug in the refrigerator again. You should have full use of the panel buttons now.
Why is it stuck on PEO OOO?
Did you change a control board? Most times this happens when you change the motherboard and its not programmed for that refrigerator what we're going to have to do is get your model number and there's a code below your model number inside the refrigerator get me that and I'll try to help you find the instructions to reprogram your motherboard
Dec 01, 2015 | Refrigerators
How do I reset or reboot my maytag fridge. I already replaced the control panel. MFI2568AES
SOME FRIDGES HAVE A RESET BUTTON IN THE CONTROL BOARD OR ON THE CONTROL BOARD
Apr 01, 2015 | Maytag Refrigerators
I have a Maytag refrigerator MFI2266AEU about 7 years old. The ice and water dispenser do not work as well as the controls. What might be the problem?
Basic diagnostics: make sure there is water supply line running to the unit and has water. If this is the case check to make sure the water supply line isn't crimped and is charged (has water pressure). If this is the case look for line blockage in the internal lines of the fridge. Make sure that all fuses are intact, there are no ground faults, and there is power to the control board. Make sure all ribbons are in tact and there are no breaks. Check for water damage on any of the sensors or other electronics which could be kicking fuses or internal breakers.
Jan 28, 2015 | Maytag MFI2266AEU Refrigeration :...
Cannot reset the filter light on our maytag mfd2562kes
Unplug the fridge from the A/C receptacle for 30 seconds. Then, plug it back in. Sometimes this resets the computer board inside the fridge.
Apr 24, 2017 | Maytag MFD2562KES Stainless Steel Side by...
I have a frigidaire fridge model # FSC238F7DSBA I had a blinking error of " E F" on the control panel. I checked out the error codes as well as called frigidare customer service and they both led me to...
After replacing the control board did you unplugged the fridge.?There is no resetting button.Unplugging the fridge for 1 hour will reset it.If still the fridge doesn't reset then leave it over night unplugged.
Thank you
Oct 19, 2010 | Frigidaire Refrigerators
I have this fridge: jcd2295kes jenn-air technician replaced some control panel in the back of the fridge yesterday now temp controls are flashing PEO and 000 and fridge is not working they cant get...
For starters, use a couple of styrofoam coolers to protect your food. Then you can wait for the tech to return. The symptoms you now have are related to his work so he will want to fix it.
Feb 25, 2010 | Jenn-Air JCD2295KES Stainless Steel
Maytag MFI2266AEU Water and ice dispenser locked, control panel
Door Panel Locked
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue pressing Freezer "-". You will see PE _ _ _ _.
Press Freezer "-" until PE # # # # shows on the panel.
Using Freezer "+" to move cursor, Refrigerator "+" and "-" to change numbers, bring all numbers to "0". Press Freezer "-" until PE and numbers blink. Unplug refrigerator for 45 seconds, never beyond 1 minute or you'll have to start over.
Look inside refrigerator door and locate the serial sticker. To the right of the serial number is the CODE ####. Plug in your refrigerator.
Press Door Alarm and Freezer "-" at the same time, then release Door Alarm but continue to press Freezer "-". Using the same method as above, enter the four digit CODE number you found on the serial sticker. Press Freezer "-" until PE and numbers blink. You have just reset your panel. Unplug for 45 seconds. Plug in refrigerator and you should now have full use of your door panel.
This unit has a built in safety timer mechanism. If it dispenses water for two minutes, it assumes it is flooding your house and shuts the panel down. If you are filling a pitcher of water, just stop dispensing halfway through to reset the safety timer.
Feb 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
I have a Maytag model no: MFI2568AEB I replaced the HV Control board in the back, when plugged in the front panel now reads PEO OOO and the you cannot put your code in O3O2 all freezes, please help. Thank...
i would unplug and start again,refer may be board.as you seem to know with out that code in there it wont work[been there done that]and you have to read carefully and do just as instructions say to pull it off.you can do it though. God bless ,tom
Jan 24, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2266AE Side by Side Bottom Freezer French Door Refrigerator Logo
2,645 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
